I cant realy comment on adjusting fueling mate as I''ve never done it.
Other things could affect requested fueling. I wouldn't loke to guess what it could be mate.
new logs after fitting phenolic gasket.... note the poor maf readings, i unplugged the maf and the stuttering on low revs i was seeing dissapeared so id say maf is on its way.
Code:
Group A:	'003				Group B:	'115				Group C:	'020
	Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
TIME			Angle Sensor 1	Timing Angle	TIME			(specified Value)	(actual Value)	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	 %	 mbar	 mbar	STAMP	°KW	°KW	°KW	°KW
0.61	2680	67.86	100	18.8	0.01	2440	57.1	1340	980	0.31	0	0	0	0
1.52	3080	103.11	100	5.3	0.91	2800	135.3	2300	1780	1.21	3	0	3	3
2.42	3600	120.5	100	4.5	1.82	3240	176.7	2280	2320	2.12	3	0	3	3
3.33	4120	137.72	100	6.8	2.72	3760	174.4	2190	2280	3.02	3	0	3	3
4.23	4600	148.28	100	10.5	3.63	4280	173.7	2120	2210	3.93	3	0	5.3	3
5.14	5080	159.5	100	9	4.53	4760	168.4	2080	2090	4.83	2.3	3	5.3	6
6.05	5480	164.11	100	10.5	5.45	5240	162.4	2070	2010	5.74	2.3	6	5.3	6
6.96	5880	167.81	100	11.3	6.35	5640	152.6	2050	1890	6.64	2.3	6	4.5	5.3
7.86	6200	168.08	100	14.3	7.25	6000	146.6	2010	1870	7.56	1.5	5.3	4.5	5.3
8.77	6520	157.47	100	18	8.15	6320	139.1	1900	1810	8.46	1.5	5.3	3.8	4.5
Code:
	Group A:	'003				Group B:	'118				Group C:	 Not Running
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Intake Air	Charge Pressure	Charge Pressure
	TIME			Angle Sensor 1	Timing Angle	TIME		Temperature	Solenoid Valve	(actual Value)	TIME
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	°C	 %	 mbar	STAMP
	0.3	3120	82.39	96.5	22.5	0.01	3040	13	86.3	1150
	0.9	3400	118.72	98.8	6.8	0.6	3240	13	86.3	1850
	1.51	3760	128.86	100	9	1.2	3560	12	85.5	2170
	2.11	4120	138.97	100	8.3	1.81	3920	12	84.3	2230
	2.71	4440	146.58	100	15	2.41	4280	12	83.9	2200
	3.33	4840	156.11	100	9.8	3.02	4640	14	85.1	2070
	3.92	5120	161.42	100	13.5	3.63	4960	15	84.7	2070
	4.53	5400	164.47	100	13.5	4.23	5280	16	86.3	1990
	5.14	5680	166.5	100	15	4.83	5520	17	86.3	1910
	5.74	5920	167.56	100	15	5.43	5800	18	86.3	1870
	6.34	6120	171.03	100	14.3	6.03	6040	19	85.5	1850
	6.95	6320	168.89	100	17.3	6.64	6200	21	82	1830
	7.55	6480	157.5	100	24.8	7.25	6400	21	79.2	1760
only logs i could do as it started snowing...
quick one ontop of this, when i unplugged the maf the car started misfiring, vagcom codes were cylinder 1 and 2 random misfire
is this related to the maf or are the coils dying also.... could this explain my recent running lean on previous logs??
also note the logs were done 30mins after a 60 mile round trip so inlet temps a little higher than on a cold run, outside temp circa 2 degrees
maf officially knacked, run with unplugged, runs fine, hesitancy gone, hopefully this is the source of the leanness.
pipercross foam huge filter on the way, i know bill doesnt like these but backdraft recommend them, so ill be different and try it. it is fappin huge aswell.
should raise some more g/s.
finally getting somewhere on this, ill relog afterwards.
now for the abs problem and the whining noise and hopefully she will be there.
new logs after pipercross foam filter and oil change.....
Code:
Tuesday	2	March	2010	12:37:53
06A 906 032 HN		1.8L R4/5VT         0002
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	 %	 mbar	 mbar	STAMP	°KW	°KW	°KW	°KW
	0.01	2720	31.56	18	25.5	0.26	2800	104.5	1740	1270	0.56	0	0	0	0.8
	0.86	3080	100.67	100	10.5	1.16	3240	167.7	2060	2090	1.46	0	0	0	0.8
	1.76	3560	114.08	100	9	2.07	3720	166.2	2140	2080	2.37	0	0	0	0.8
	2.67	4080	139.11	100	11.3	2.97	4240	178.2	2120	2170	3.27	0	3	0	0.8
	3.57	4600	153.19	100	12.8	3.89	4760	175.9	2120	2080	4.18	3	3	3	6.8
	4.48	5080	168.89	100	9.8	4.78	5240	169.2	2090	2020	5.08	3	6	6	6.8
	5.39	5520	172.14	100	11.3	5.7	5640	163.2	2050	1890	5.99	3	6	6	6
	6.29	5880	177.08	100	9.8	6.6	6000	154.9	2010	1900	6.89	2.3	5.3	5.3	6
	7.21	6200	174.31	100	12	7.51	6280	142.9	1910	1770	7.81	2.3	5.3	5.3	5.3
Code:
Tuesday	2	March	2010	12:36:09
	Group A:	'003				Group B:	'118				Group C:	'031
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Intake Air	Charge Pressure	Charge Pressure		Lambda Sensor	Lambda Sensor	Bin. Bits
	TIME			Angle Sensor 1	Timing Angle	TIME		Temperature	Solenoid Valve	(actual Value)	TIME	Current Value	Specified Value
	0.56	2800	76.75	99.2	18.8	0.01	2600	18	86.3	1060	0.26	0.891	1
	1.46	3200	108.89	100	7.5	0.86	2920	18	86.3	1790	1.16	0.984	1
	2.38	3720	128.06	100	6.8	1.78	3400	18	86.3	2220	2.07	0.992	0.961
	3.27	4240	143.56	100	10.5	2.67	3880	18	85.1	2210	2.97	0.922	0.945
	4.18	4720	155.69	100	9	3.57	4400	19	84.7	2140	3.88	0.93	0.922
	5.09	5200	167.28	100	10.5	4.48	4880	21	85.9	2090	4.78	0.922	0.906
	5.99	5600	172.39	100	12.8	5.39	5360	23	86.3	1980	5.69	0.899	0.906
	6.9	6000	176.5	100	11.3	6.3	5720	24	85.9	1910	6.59	0.891	0.899
	7.81	6320	171.03	100	12	7.21	6080	26	83.9	1900	7.51	0.891	0.899
	8.71	6560	161.94	100	21.8	8.11	6400	27	80	1740	8.41	0.914	0.922
Code:
Tuesday	2	March	2010	12:33:21
	Group A:	'003				Group B:	'118				Group C:	'020
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Intake Air	Charge Pressure	Charge Pressure		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME		Temperature	Solenoid Valve	(actual Value)	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	°C	 %	 mbar	STAMP	°KW	°KW	°KW	°KW
	0.55	2760	73.33	98.8	18	0.01	2560	18	5.1	1190	0.25	0	0	0	0
	1.46	3200	106.89	99.6	10.5	0.86	2920	18	86.3	1760	1.16	0	0	3	0
	2.37	3720	125.61	99.6	12.8	1.76	3400	17	86.3	2140	2.06	0	0	3	0
	3.27	4240	147.67	100	9	2.67	3920	17	85.5	2180	2.97	0	0	3	0
	4.18	4760	158.25	100	13.5	3.58	4440	18	85.1	2160	3.87	3	3	2.3	3
	5.08	5200	168.22	100	13.5	4.49	4920	19	86.3	2060	4.78	3	6	5.3	3
	5.99	5640	173.19	100	12	5.39	5400	21	86.3	1960	5.69	3	6	5.3	3
	6.89	6000	177.89	100	13.5	6.29	5760	23	85.9	1900	6.59	2.3	5.3	4.5	2.3
	7.8	6280	170.78	100	17.3	7.19	6080	24	83.5	1840	7.49	2.3	5.3	4.5	2.3
whining noise has subsided slightly after the service, picks up well now, feels quick....
outside temp slightly warmer today at 5 degrees.
also reversed dv now..
Airflow looks better but you could still get a tad more out of it...
Fueling is still a little lean for me though.
yeah, literally just put the filter on, looking at a air feed to it next...
gonna have to go to will i think on the lean fuelling.
running out of things to do now
mines strait onto the maf for now, waiting on a silicon pipe to straiten the airflow out a bit, may add a bit more.
ill reset the ecu to clear the learned maf values and try again from there.
some more logs done this morning
Code:
Wednesday	3	March	2010	08:23:19
06A 906 032 HN		1.8L R4/5VT      01 0002
	0.01	2440	23.5	14.9	25.5	0.3	2520	82.7	1550	1110	0.6	0	0	0	0
	0.9	2720	79.94	100	15	1.21	2840	159.4	2240	1900	1.51	0	0	0	0
	1.81	3160	106.89	100	7.5	2.11	3360	178.2	2160	2170	2.41	0	0	0	3
	2.71	3680	117.03	99.6	6.8	3.02	3840	178.9	2090	2130	3.32	0	0	0	3
	3.62	4160	140.89	100	11.3	3.92	4320	181.2	2050	2150	4.23	0	0	3	6
	4.53	4640	161.22	100	11.3	4.83	4840	178.9	2050	2080	5.13	3	6	3	6
	5.43	5120	171.61	100	10.5	5.73	5240	173.7	2060	1980	6.03	3	6	2.3	6
	6.35	5520	176.14	100	12.8	6.65	5680	162.4	2030	1930	6.95	2.3	5.3	2.3	5.3
	7.24	5880	180.69	100	12	7.54	6000	157.9	1980	1880	7.85	2.3	5.3	1.5	5.3
	8.15	6200	177.89	100	10.5	8.46	6320	145.1	1890	1760	8.76	1.5	4.5	1.5	4.5
that was with 5% fuelling on inc load added
this is with 10% added on increasing load
Code:
Wednesday	3	March	2010	08:32:48
	Group A:	'020				Group B:	'031				Group C:	 Not Running
		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Lambda Sensor	Lambda Sensor	Bin. Bits	Bin. Bits
	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME	Current Value	Specified Value			TIME
Marker	STAMP	°KW	°KW	°KW	°KW	STAMP					STAMP
	0.01	0	0	0	0	0.24	0.906	1
	0.55	0	0	0	0	0.85	0.977	1
	1.15	0	0	0	0	1.45	1.016	1
	1.75	0	0	0	0	2.06	0.984	1
	2.36	0	0	0	0	2.66	0.969	0.984
	2.96	0	3	3	0	3.26	0.961	0.953
	3.56	3	3	3	3	3.87	0.922	0.93
	4.17	3	3	3	3	4.47	0.914	0.922
	4.77	3	3	3	3	5.08	0.914	0.914
	5.39	2.3	2.3	2.3	2.3	5.69	0.906	0.914
	5.99	2.3	2.3	2.3	2.3	6.28	0.922	0.914
	6.59	2.3	2.3	2.3	2.3	6.89	0.906	0.914
	7.19	1.5	1.5	1.5	2.3	7.5	0.922	0.938
cfs much much better
tried adding some timing just 1.5 degree added gave this
Code:
Wednesday	3	March	2010	08:50:30
	Group A:	'003				Group B:	'031				Group C:	'020
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Lambda Sensor	Lambda Sensor	Bin. Bits	Bin. Bits		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME	Current Value	Specified Value			TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP					STAMP	°KW	°KW	°KW	°KW
	0.3	2840	59.47	69.4	26.3	0.6	0.899	1	        	        	0.01	0	0	0	0
	1.21	3200	107.14	100	8.3	1.51	1.008	1	        	        	0.9	0	0	0	0
	2.11	3720	129.5	100	9	2.41	0.977	0.961	        	        	1.81	0	0	0	0
	3.02	4280	145.08	100	9	3.32	0.922	0.945	        	        	2.71	0	0	0	0
	3.92	4760	161.19	100	9	4.22	0.938	0.938	        	        	3.62	0	3	6	0
	4.83	5200	174.08	100	10.5	5.13	0.906	0.906	        	        	4.53	3	3	6	6
	5.74	5640	177.61	100	14.3	6.04	0.875	0.899	        	        	5.43	3	6	6	6
	6.64	6000	179.58	100	14.3	6.95	0.899	0.899	        	        	6.34	2.3	6	5.3	5.3
	7.55	6320	174.97	100	12.8	7.85	0.899	0.914	        	        	7.25	2.3	5.3	5.3	5.3
so i put back to 0 timing advance
looks better to me with the fuelling added, cf dropped with 10%.... but does fuelling look right??
comments welcome
fuelign looks better to me.. better to see 0.8xx under boost once spooled.
your first log did'nt have fueling tho
