Should fit straight on if you searched based on car. Not sure.on spacers mate as never had any. I did notice my wheels only.clear the front calipers by mm so not sure if that may cause problems with different wheels?
Sent from my C6903 using Tapatalk
If your getting any get the 9.5j for the concave! Don't get 8.5 don't look no where near as good
I have 9.5 grid drifts with 5mm spacer on front ( need it so doesn't hit suspension) with 225/40 18 tyres sticks little wider than arch but legal
Not the best pictures but you get the drift.... Just look at that concave!
Or these not many people run these on lcr'a xxr 527
These sat flush with mine
Nowt wrong with Rota quality these days ............. thats why they drift them . If you race, yeah fair enough ,then pay 4 x the price for forged but otherwise cast is fine. The cast only break if you loose it and smack a high kerb sideways on ........ summats got to give ........ if your on forged rims it will just turn the wish bones into a u shape instead or rip them off the subframe !
How about Rota Force in Gunmetal ......... cool factory tuned look .
Put it into google and clik photo to see loads of cars with rota force fitted.
Standard LCR is 7.5 et 38 and 5x100
Try "Will they fit .com " put the above details in and your new wheels details and it will tell you the new poke etc
for what its worth sc22 wheels in his pics dont look legal to me ......... but hell what do I know .......... you will shower your self in stones on the roads out here in the sticks.
Cheers for that.. all the sites seem to think 8.0 et48 5x100 will fit..infact I even selected 7.5 on one and it became 8.0 later on.. will double check on the phone 2moro but all being well should have some new rims on by Wednesday :D
ET48 would give less poke than the standard wheels! Your biggest issue with wheels will be caliper clearance, I'd look at a smaller offset.
EDIT: just calculated it, the Lensos would have ~16mm less inner clearance and would retract ~4mm from the outside.
As long as your tread is in the arches it is legal.. I have stretch so it's only the sidewalls what stick out never had a problem when been pulled
I was looking at rota force recently and the best fit in 17" was 8 inch with 35 et offset required no spacer
Rota grid in 7.5 et 45 again in 17 inch and no spacer
my needs are for road / track days rather than style I should add ! so feel free to ignore if your after style statement above all else
QUOTE=hyphon12;4343676]ET48 would give less poke than the standard wheels! Your biggest issue with wheels will be caliper clearance, I'd look at a smaller offset.
EDIT: just calculated it, the Lensos would have ~16mm less inner clearance and would retract ~4mm from the outside.[/QUOTE]
Im confused now.. was gonna order these but dnt want negative poke or issues dispite the site saying they fit the car
http://www.performancealloys.com/wheel-details.aspx?ID=1896
Lower the et more they stick out higher the et more they stick in the arch :)
Personally I would try get a et of 35 seem to fit well on all the wheels in fit with that offset
