Nils's Ibiza 1.8 20vt FR - 251 BHP & 405 NM - New Vid!! 0-62mph in ...
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
25-07-08
I'm Nils, 24 years, and I come from the Netherlands.
This is my car since the 25th of july 2008.
Seat Ibiza 1.8 20vt FR
Build 07-2004
Mileage 66.000 km
Besides a leather interieur it's fully optioned
Cupra front bumper
Cupra back bumper
Everything sprayed in color
Fog light plates in color
Keyless doorhandles
2006 back screenwhiper
Really looks new :)
I'll use the first posts to keep up my project. Click on the multiple images to view the complete picture gallary's.
05-07-2008
Pics when I bought the car
29-07-2008
Forge Split-R
Today I mounted a Forge Split-R and I ve done the N249 mod
The sound is a bit disappointing. Maybe it gets better when I get my remap.
Also I mounted my Alpine HU today with Ipod interface adapter and I began to mount my JBL compo speakers in the doors.
And just made an appointment with JD engineering. The best 1.8 20vt remapper from the Netherlands
13 august is my time!! I'll get a custom remap at a dyno.
08-08-2008
I mounted an original pre-facelift FR bumper on my Ibiza. With the cupra bumper I don't have a good working intercooler and than the custom remap would not be the effort.
Also got my turbo pressure gauge and oil temperature gauge mounted.
Bought a Pipercross foam filter
13-08-2008
Visited JD Engineering today!!
He also programmed the car so I don't need my air flow meter anymore. Right now I can let my Blow Off Valve, blow off all air without any problems.
This is the result of JD:
The Torque really is amazing. The top performance could be better, but than I would have to mount another exhaust and a front mounted intercooler. I'm really happy with the results of this standard FR.
Now doing:
214 HP @ 4800 rpm
341 Nm @ 3300 rpm
18-08-2008
The Previous owner of my Seat Ibiza FR 1.8 20vt with smic, mounted an Cupra bumper on the car, but as I was planning to get a custom remap at a dyno, I had to find a solution to get back a good working intercooler. A front mounted intercooler from Forge or the original one from a Cupra (D) cost over a 1000 Euro without mounting. So I modded the Cupra bumper to get some cold air into the smic.
To make sure my modifications work, I've done some logging with Vag-com of the inlet temperature with my pre-facelift FR bumper and the Cupra bumper
First I drove my car easy to normal work temperature (About 95°C on my oil temperature meter). Then I make sure my laptop was ready to log group 4 of Vag-com. This group logs the engine RPM against the inlet temperature. Then drove to 1000 rpm in third gear an than floored to 6500 rpm. All logs were done on the same day with the same outside air temperature and humidity on the same road.
- FR Bumper log 1 - Outside: 19°C - Oil: 97°C - Water: 97°C
- FR Bumper log 2 - Outside: 19°C - Oil: 100°C - Water: 100°C
- Cupra Bumper log 1 - Outside: 19°C - Oil: 97°C - Water: 97°C
- Cupra Bumper log 2 - Outside: 19.5°C - Oil: 100°C - Water: 96°C
As you can see the inlet tempereture get's much higher on the second run with both bumpers. Can you imagine how much power loss this gives when you step on it for only ones.. I did not do a third run, but it could be the power loss would even be more as the turbo warms up the intake air even more when the engine is getting warmer and warmer. This also is because I modified my car to run on much higher turbo pressure and the intercooler is not optimal for that amount of air.
The best thing is that it's very clear that the intercooler does a better job with the Cupra bumper mounted, as it is with an original FR bumper. All my work was not for nothing.
08-08-2008
Repaired the FR rim. It was damaged when I bought my Ibiza. Click on the picture for a before/afte gallery.
10-09-08
Bought some cleaning products today. I did not have any before since I live in my own appartment so I bought everything at ones at an carcelan specialist.
Kärcher high pressure water cleaner
Meguiars - NXT Generation Car Wash Shampoo
Meguiers - Quick Detailer
Meguiers - Medium Claybar
Meguiars - NXT Generation Techwax 2.0 pasta
Meguiars - Color X
Meguiars - Gold Class All Metal Restorer
Wheelwax - Wheelwax
Poorboys World - Trim Restorer
Meguairs - Ultimate Washmit
Valma - Soft spons
CarClean - EZ Detail Auto brush
Mothers - Wheelbrush
CarClean - 2 sided mini brush
3 Hi-Tech - Foam applicator
Lake Coutry - Red Ultra Soft Foam Hand Polish Applicator
Poorboys World - Waffle Weave Drying Towel
Poorboys World - Deluxe Mega Towel Yellow
Poorboys World - Deluxe Mega Towel Coral
12-09-08
I cleaned my car in two days for about 12 hours. Really did a good job cleaning all parts with a brush that are usually forgotten like all doorpins and seams
results:
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
16-09-08
Mounted 20mm spacers today. A H&R DRA system, really good quality spacers and I can keep the original bolts.
Click on the pic to view good before/after pictures.
26-09-08
New Tyres. Goodyear Eagle F1 GS D3 in 215 40 ZR16
With the new tyres I went to an truck weigh plate to weigh the car. It is 1220 kg with a full gastank. After that I calibrated the Gtech Pro RR to performe a proper measurement. The results are amasing. Not all run's are finished all the way, some times I had te loose the gas early, that's why there are differences in the quartermile times. Outside air temperature was 19°C
6.1 seconds to 100km/h (60mph) :)
28-09-08
Photoshoot in a doc in Rotterdam
01-10-08
Mounted a HKS SSQV
Gives a real impreza like blow off sound
10-10-08
Best mod. until now!!
Click on the pic below for a beofre/after gallery.
Audi TT/S3 brakes, brembo 312mm perforated discs and pagis brakepadset zijn dus Audi TT remklauwen met 312mm geperforeerde Brembo schijven en Pagid remblokken. It brakes perfect!!
20-12-08
Mounted a new turbo inlet pipe.
25-01-09
Mounted a Seat Sport Cupra Intercooler. I used as less silicon tubes as possible and welded most of the system of stainless steel tubes.
12-02-09
A Dyno run with the new intercooler, without a new remap already gained 20hp. The torqua comes in a little later thoug.
Blue is wheelpower (HP)
Green is enginepower (HP)
Purple is torque in Newton Meters (NM)
Red is driveline power lossRood is de weerstand in de aandrijflijn (die wordt gebruikt om van het wielvermogen het motorvermogen te kunnen berekenen)
230HP @ 6100 rpm
324NM @ 4000 rpm
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
19-02-09
Mounted an ATP 3 inch decat downpipe.
Removed second lambda sonde.
24-02-09
Without remapping done some sprinting from 80 to 120 km/h
http://www.seat-online.nl/forum/index.php/topic,45249.600.html
The first movies shows that VCDS is right and gives the exact same speed as GPS. The car itself till 100km/h has 2,5 km/h difference, and above 100km/h the car has a 5 km/h difference with GPS speed.
Best viewed at 200%
120 km/h on GPS -> 125km/h in car
80 km/h on GPS -> 82,5km/h in car
80-120 km/h in 3,1 seconds.
80-120 in 3 in 3,1 seconde (ook met de stopwatch gemeten in 3,1s)
And a 100 to 160 km/h
06-03-09
Mounted a Milltek 2.5 inch Catback Exhaust
17-03-09
Done some small changes. Changed oil with Kendall Elite 5W50 racing oil an mounted NGK BKR7E bougies.
26-03-09
Car is remapped again!!
251HP and 405Nm torque.
While remaping there were some trouble with the fuel system. The original injectors couldn't give enough fuel. This is why the car is now limited at 6000 revs.
I bought some Genisis 550cc dual spray injectors. They will arrive in 3 weeks. The car will be remapped after.
01-04-2009
Changed suspension to KW Variant 2. A Seat Sport strut brace is ordered as well.
05-04-2009
A photoshoot with the KW suspension.
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
Current specs
- Custom TVS Engineering Remap
- 251 hp @ 5146 rpm
- 405 Nm @ 3593 rpm
- 0-100km/h in 5.7s
- 80-120 km/h in 3.0s
- 100-160 km/h in 6.8s
Engine
- Genesis 415cc dual spray injectors
- Cupra D Airbox Intake
- Pipercross Foam Filter
- HKS SSQV
- Optimised turbo inlet pipe
- Seat Sport Cupra Front Mounted Intercooler
- 3 Inch deact downpipe
- 2,5 inch Milltek Catback Exhaust
- NGK BKR7E Bougies
- Kendall 5W50 Elite Oil
Dynamics
- 5mm spacers in front
- OZ Ultraleggera Matt Graphite Silver in 17x7,5J ET35
- Audi TT/S3 brakes
- 312mm perforated Brembo discs
- KW Variant 2 suspension
Exterior
- Keyless doorhandles
- Everything sprayed in Color
- Cupra front bumper with painted foglight covers
- Cupra back
- 2006 back screenwhiper arm
Interior
- Turbo pressure gauge
- Oil temperature gauge
- Alpine CDA 9855R Headunit
- JBL Compo speakers
- Class III Alarm
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
Mounted soon
New larger mass airflow meter
Synapse BOV
Seat Sport Strut Brace
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
15-09-2008
This was it for now. Plannings for the near futere are to mount some 20mm H&R spacers on the FR rims and to buy the best tires there are in 205/45/16 because it is really hard to get all power on the road on wet days.
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
Great write up. The car looks spotless in the last pictures!
Your logging with the Cupra bumper mod has helped me aswell, so thanks for that :)
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
It's been a while since I updated my project here.
The last update was on 29-07-2008 so the rest is new here :)
Thers's been a lot of changes since.
I've done this photoshoot today with the new KW suspension.
RpR
172
Denmark
251hp / 401nm :drool:
What on earth do you feed that thing? 108 octane? :p That engine must be running some serious boost to get that old k03s to deliver this much power!
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
The boost at 3000 rpm is 21.7 to 22.5 psi (1.5 to 1.55 bar). Together with that 3 inch downpipe gives that amount of torque.
The boost at 6000 rpm is still between 15 and 16 psi. (1 to 1.1 bar), which gives the high BHP.
Running on octane 98, but with a very large intercooler.
And I have got a very good remap from TVS Engineering in Aalten (Netherlands).
nils 6l
Dutch Driver
Aug 9, 2008
61
Netherlands
Not really. Here in the Netherlands a lot people drive with there turbo on the max.
And actually, if it blows up, it's a good excuus for the misses that I'll need to buy an IHI, Garret or K04s :whistle:
Dec 5, 2007
882
Kilmarnock, Ayrshire
Hey Nils,
Your car is stunning and your pictures - waw! They are such good pictures with really good settings, love the shoot with all the containers stacked!
Very nice work
