theres no water comming from my rear wiper but its working fine at the front of car. water level is fine, any ideas whats wrong or how i can sort it?
thanks
Sounds like it's suffering from the common problem of the hose coming loose somewhere. Hope you haven't tried it too much, incase your boot's now flooded.
so i take it theres 2 lines for front washers and the rear then, iv checked boot nw gunna check in engine bay. will u see the water when u try and do it? or do things need removing to see?
with mine as soon as you pressed the rear wash wipe it was clear where it was coming from as it sprayed out and a huge puddle appeared! from memory the line runs along the n/s of the engine bay
