chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
theres no water comming from my rear wiper but its working fine at the front of car. water level is fine, any ideas whats wrong or how i can sort it?
thanks
they normally pop off in the boot or the engine bay, do a search theres loads on here about it!
I remember my old Corsa did that years ago. Was blocked at the pump in the engine bay and squirted screenwash everywhere in there!
so i take it theres 2 lines for front washers and the rear then, iv checked boot nw gunna check in engine bay. will u see the water when u try and do it? or do things need removing to see?
with mine as soon as you pressed the rear wash wipe it was clear where it was coming from as it sprayed out and a huge puddle appeared! from memory the line runs along the n/s of the engine bay
just stand back when you switch the washer on otherwise youll get washed! great trick to play on a friend! lol
found where the leak is. its under the car about half way. havent jacked it up yet but is there any connectors there or straight hose.
ooo not herd of it coming from there! dont know if there any connectors under there sorry, let us know how you get on
