here we go.
and before anyone says it, i know it needs turning a bit to get it dead upright.
couldnt be arsed today when i noticed.....i will do it tomorrow. :)
just a few to keep you going!
Was it an easy job cupra brown? im hoping to get mine in this weekend. How long did it all take and how was the fit of the pillar pod? Looks good mate, well done!
tbh it wasnt to bad. the worse bit is getting the pipe through the bulkhead. Took 2 of us :) rest is pretty straight forward really....
the fit of the nomad pillar is absolutly spot on...... however i used industrial velcro which sticks like sh#t to a blanket! this really helped the overall fit of it..
good luck with it daniel....
what was the problem with getting the pipe through? will i need some help? I think im going to need some good luck mate but hey i will give it a good go!
Tape it to a wire coat hanger and get someone to poke it down, there's a lot of crap in the way to grab it though.
lots of crap. plugs , plug frame things wire looms etc.
i gave up and took the bottom of the dash off int he end to make it possible to find the pipe :)
All done mate :funk: Took a few hours and a bit of help from the mrs but all in all not too bad. But im not too sure what the gauge should be reading?
i'll give you a hand, if i ever get round to doing mine.
what have you gone for? boost and....?
if oil, did you get a sandwich plate? makes it much easier to add additional sensors.
will go oil temp
me and james were discussing and might go with electrical
