Thanks. It was cleverspoon. He mentioned I should look at the temperature of the coolant on there when its fluctuating to see if it is a dash issue or the actual sensor/engine parts failing. Do you agree with that?
Yeah, also vag com can register the coolant temp, and yu can log it to see if it fluctuates.
Sorry.....didnt realise there was 2 pages, so read the first page then thought id comment. No sorry mines not for sale.....i kerp getting a fault light due to a dodgy cts....but seeing as its common for the sensor / stat to fail i thought id do a bit of research.
Out of interest what does your climate control read? If you press the recirc button then the up arrow(to select top vents) at the same time the screen should read 1.....then press temp up button to read 51 then press recirc button to select 51 it should then read the coolant temp. I think lee69 has a guide on how to do this. Im wondering if you have tried everything else you may have a faulty unit on dash? Possibly moisture from various leaks on these cars such as fuse pannel in scuttle.
Did you use temp up to 51 then press the recirc button to enter 51?
You only seen the 1c you need to do more
You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
As far as i understand the cts is a 2 in 1...one part tells the ecu/ climatronic (thats where you were reading 90c) and the other part of the sensor tells the dash what to display.....it may be that the part of the sensor that supplys the dash is faulty....or the dash itself, i imagine it would be cheaper to try a genuine cts.....but check the plugs etc first. Apart from that i dont know much more....all i know is what iv read on here (iv read a lot haha)
I went to ecp to get some g12 for when i do mine......he said g12 has been replaced by g13 the purple stuff.....he said its compatible with the pink/orange stuff. I hope it is!!
