Deleted member 123864
It's in Post #60I have write this
can anyone tell me what exactly I have to code. or where to look exactly?
Thanks for your help![]()
Not really sure, as mine had heated steering wheel to begin with, so I didn't have that problem. If it's coded in the central electric module, then I think you are in trouble, as that might be locked by SFD. I'm on vacation right now so I can't look up my settings at the moment, but try and see if there is anything regarding heated steering wheel in long coding for the central electric and air condition modules?
Sorry, I misunderstood. I thought your old steering wheel was unheated, in which case the new one would have an extra plug for the heating wires. Since the old one was also heated, I would have expected it to be plug and play, not sure why it doesn't workWhich extra plug?
I had the steering wheel installed, so it was said that the plugs are internally connected.
Yeah, same experience for me unfortunately. I don't actually think it is capacitive at all, which also seems to be backed up by various comments and videos on other sites. Looks like the facelifted Ibiza and Arona may be the first Seats to have a proper capacitive steering wheel.You don't notice much of the capacitive steering wheel either, how is it with you?
Hello,Hello everyone i have a 2018 vw polo and have retrofitted the touch mk8 golf steering wheel but i have a problem,when using the Travel Assist and not having my hands on the steering wheel even for a second i get the message (Take over steering) constantly unless i have both hands on the wheel...My A5 camera is 2Q0980653 now before this touch steering wheel was fitted i had my normal steering wheel fitted which gave me the lane assist option (Adaptive Lane Guidance) and it did the same thing with this too
So im wondering if anyone has come across this problem too and what did you do to solve this?
Any help would be great
thanks
Scott
Hello thanks for your reply,but when you watch the videos for Adaptive Lane Guidance or Travel Assist you can 100% take your hands off the steering wheel for say 10 seconds at least.Hello,
Regardless of the timing for the warning to activate, this is precisely the point of the capacitive steering wheel: not having the warning as long as you have your hands on the wheel even if you don’t do any movement.
it’s not made to allow you to drive your car hands free
I know what you meant, I just pointed out it's normal.Hello thanks for your reply,but when you watch the videos for Adaptive Lane Guidance or Travel Assist you can 100% take your hands off the steering wheel for say 10 seconds at least.
Well, so far the main thing is to be able to remove the warning to take over the steering wheel and no one found how.Most accessory shops in Turkey activate this feature, has anyone tried it for Leon without changing the steering wheel?
It could be the lane assist I saw, I'm posting pictures of it. Turns on feature as adaptive cruise controlWell, so far the main thing is to be able to remove the warning to take over the steering wheel and no one found how.
but you can activate adaptive lane guidance which is pretty much like travel assist
