Deleted member 98136
kiddo,I couldn't find a setting in Infotainment settings menu. Did a factory reset and now have lock / unlock chirp
Previous coding appears to have stayed.
is yours a prefacelift or a facelft version ?
Thank you
Yes I know what you mean regarding previous version, enabled on mine with no problem and I don't remember having to do a reset either.The issue seems to be that on the facelift cars the original coding either does not work or it only makes a tiny noise that cant be heard.
The above coding implied that there was some stuff that could be changed that would make it work. As I don't have access to one I am afraid I cant play with the settings to see if its possible. On my car (the original coding) it worked perfectly first time (once I had done the factory reset).
Afraid this is where you have to make changes and see if it works on your car or not.
According to the spanish site
All models - This has been tested up to MY18
With this mod you can make that when closing, opening or in both cases there is an audible signal with the horn.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Response signals
4 - Akustische rueckmeldung entriegeln - (Change value to On) (It will give two beeps when opening)
5 - Akustische rueckmeldung verriegeln - (Change value to On) (It will beep once close)
6 - Akustische rueckmeldung global - (Change value to On)
7 - Akustische rueckmeldung signalhorn - (Change value to On)
8 - Menuesteuerung akustische rueckmeldung - (Change value to On) (On-screen menu)
9 - Dauer der akustischen rueckmeldung vom einfachhorn - Normal (Long) or Kurz (Short)
Another form
1 - Applications
2 - Lock / Unlock acoustic confirmation
But a number of people on this and other sites say it does not work anymore.
I've tried this and the other settings and it's still very quiet and intermittent on mine.This is the bit of coding I saw, but i have not been able to get hold of a new car to see if it makes any difference to the open close beep
The alarm is already working (08/03/2017), in bold the changes with respect to how it was previously.
1. Go to Module 09 - Electronic control unit
2. Enter Encoding (press up to the right, Bytes mode)
3. Go to Byte 12
4. Activate Bit 0
5. Confirm (V), code 31347
6. Go back, to Adaptation, same module
7. Enter anti-theft device
8. in DWA Alarmverzoegerung, change value to "Driver door contact thatcham"
9. in DWA Camper Modus, change value to "On"
10. in Ueberwachung Innenentriegelungshebel, change value to "On"
11. (optional) in Sirenen Alarmzahl, put the number of times it will beep when the alarm goes off, you can put 1 or 10, by default it is already 10.
12. in Akustischer Alarm Signalhorn, change value to "On"
13. in Diebstahlwarnanlage, change value to "On"
14. Confirm, code 31347
fifteen.
16. To make the horn sound when opening / closing:
17. Go to Ring the horn when opening and / or closing the car
The detection possibilities of the OEM alarm:
• Someone breaks a window, passes the arm and opens the door with the door handle ... the alarm sounds.
• Someone breaks the driver's window, passes the arm and opens the hood with the hood handle ... the alarm sounds
• Someone forces the hood with a lever ... the alarm sounds
• Someone forces the tailgate with a lever ... the alarm sounds
I wanted to consult something. The question is that I followed the instructions of the partner to activate the alarm oem and the question is that supposedly everything is correctly activated but when I try it to see if it sounds, it does not sound like nada.mi car is manufactured in October is a my18 and this issue already has me a little fly. can someone do me a cable? my version of vag com is 17.8 ...
I did this and mine is a MY18 too and it works correctly:
Go to Byte 12
Activate Bit 0
Enter anti-theft protection
in Ueberwachung Innenentriegelungshelbel, change value to "On"
Confirm, code 31347
Submenu - Response signals
Akustische Rueckmeldung global (Change value to "activated")
Akustische Rueckmeldung Signalhorn (Change value to "activated")
Mine is also a MY18 and following these same steps the OEM alarm works perfectly for me. I have to say that the horn without contact was already activated at the factory.
check out www.clubseatleon.net/viewtopic.php?f=8&t=116700&sid=d85413c0a1a093a436b510583d3ec5ea&start=4965 and use a tranlate plugin on your browser.
So in the last 20 mins I've done:Sorted. Did this from an earlier post
To get this working i had to go to infotainment settings, factory settings, restart vehicle
Needle sweep
Chirp lock
Lap timer
And cleared a few faults.
What should I do next?
...if only I could read German!
