Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
About six months ago i fitted the oil catch tank and today i thought i would have a look.
:-o what is all that crud, if i had not got a catch tank this would be in the pipes and intercoolers and its only after six months. All i can say is look at the pic's and go and buy one.
Oh and i thought i would take one of the engine bay.
Don't know to be honest, just got the sludge, mine gets in the Way of the gear selector when going in to sixth but i just bend the bracket up a bit and its ok until it moves again.
I have one of these in the making, getting it welded up, sight gauge included. That is nasty stuff in there! Are you getting water mixing with your vapour or losing any coolant, even a small amount? Looks like the mayonaisse you can get under the oil cap with coolant leaks etc.
Errrrr that looks nasty!
Could you post a picture of where its plumbed into? I think I may have to put one onto my christmas list :D
Jon
Jon
I will do mine as soon as INA sorts out the plug for the hole in the bottom as it never came with it:doh::D
by the way, with my catch can, it only has a hole in the bottom to drain crap out and its pretty much a sealed unit, but is it ok to spray like some detergent in it to clear it out once in a while?
Is there an idiots guide to fitting one ( the idiot i refer to is me lol )
you and me in the same boat mate
something needs blocking off right, as the catch can only has two fitments, one from the block and the other feed back into the block, but is there not somewhere which needs to be blocked off?
Jamie is following me around tonight , back on topic , does anywhere sell a full kit ??
Pipe from the crankcase breather (top of oil filter housing) comes up and joins pipe from rocker cover breather. Pipe into catchtank. Pipe out of catchtank to road (or into tip)
