check first... mind did come with a sender but suppliers may be different.... the length of wire that came with mine was pitifully short.. other than that it was complete
If you get an autometer oil temperature gauge it will come with the sender, as thats what I fitted in those pictures, and I totally agree with the above, you will need a long length of single core wire to go from the gauge to the sender.
Just so you know the plug in the block above the oil filter is an M10 thread and most senders are 1/8npt thread!
I got one of these adapters off eBay that lets you install oil temp and pressure senders along with the factory one too, works a treat. Just tell them what threads you have and they make it for you.
The autometer sender I got was 1/8npt and it fitted straight into the M10 hole on my car, I put a tiny amount of Loctite 577 thread sealant on before I fitted it and its been fine for 2 years.
so am i ok to fit this oil temp gauge at moment then do oil pressure im few month. All i do is contact that company and get the right part with the correct thread to allow for the both to be fitted?
