there is a build for octy on biskoda forum
http://briskoda.net/project-journals/steevie-wonders-silver-bullet-engine-build/139124/#post1623278
mine made 360bhp/350ftlbs on a vf34/20g peaking at 1.8bar so it will do it.for how long though is a different matterI thought that rolling roads are often inaccurate at calculating flywheel figures but the at the wheels figures should always either be accurate or low, but can't ever be high?
I've only had it rollign roaded twice since the IHI... once at Jabba and the other somewhere else (Can't remember where, but Bill you were there as was Wilko).... and it got 360bhp there IIRC.
Ben
i only ever ragged mine on the 1/4 mile so maybe i was lucky
the other thing is at the 350bhp levels the 1.8t copes fine(reliable)above that imo is very high maintenance not to mention the lag!in hindsight,i should of gone for a equivalent turbo tdo5/16g as it will take more boost and parts are available if things melt. also i wish i'd kept the nitrous on to add the power,my car made 415bhp/398ftlbs with ihi+50bhp of nos! all i can advise you on are my own personal experiences but 350/360bhp from a 1.8t makes for a reliable car just change the rods and stick some uprated valves in the head.my owens unit doesn't make 1 bar of boost till 4k,my ihi hit 1.8bar at 3.5k.Thanks Steve,
So are you saying that you wish you'd never gone for 425bhp?
Really my main priority for now is reliability... if I knew for sure that the engine would cope with the current 360bhp with standard internals then I'd stick with that (For now). However, if I need uprated rods/pistons then I might as well up the power at the same time.
With regards to lag (Or boost threshold) and power delivery, that's why I'd like to see a graph of the Owens turbo on a 1.8T so that I can see how it compares to the IHI.
Ben
Note that Owen Developments rate the IHI VF34 with P20 housing at 370bhp, so its not that unrealisitc is it? Plus I have the methanol injection.
Still, I'd actually be happy if the readings are optimistic... that means when I go to a true 425ish bhp the difference will be even greater than I thought.
Ben
