Fl@pper
Jun 19, 2001
12,366
24
Gloucester
At last the beefa is on the drive.
Runs ish ticks over with the inlet pipes loose at least yet naff all out the exhaust at all and no revs at all
Dodgy look underneath tracing the oil leak shows turbo appears to have split apart hmmm and underfloor looks like poor thing got a thrashing around speed bump city.
Time to jack her up and get oily . Can't wait to see what a mess theblower is in. :joystick:
Be sniffing about soon to see what options and models out there for replacements .not worried about big power modding etc as poor thing is getting on a bit
Oily time. Hehehe
That's my plan A .
Looking at it split apart gonna rip it off and see if the castings are salvageable firstly.
Has probably tried to machine itself out of there like a bouncing bomb from the matrix lol :flamed::flamed::flamed:
Struck oil .hehehe.
bumper. Headlight (is wet n foggy) and Intercooler all off and most the hosesr AndA every pipe is plastered inside n out with oil .even the air filter hose ? 4Kin everywhere
Last pipe down to turbo is loose can see the inlet snail wobbling about on the end of it so safe bet that turbo is blown . literally lol.
Well it's out. In both pieces .lol.
Was like that when I found it. Have to see if I can find the turbine bits now.
All found cleaned flushed scrubbed and serviced .
Oh and a garret replacement blower now instead at last .
Starts n runs and now the boost sensor is firmly home (code cleared ) and the load sensing wire has been soldered up properly all the pretty engine and TCS lights are gone and ready for a proper test run
There she blows .(black smoke only I hooe) lol
Noticed the lights on when unlocked but relocks when only osf door opened so ripping out the lock mechanism next and fixing drivers door window runners .
Like being back in the old MK2
Should always leave one thing wrong with it because as soon. As you fix em all something else will break hmmmm
Ripped door apart to replace the lock mech anyway and found the regulator was missing .ALL OF IT lol
Glass took 2 hours to get down as they decided to cut out the mech and silicone the glass in place OWCH
Found a mech at scrappers and swapped motors etc over
Ha ha I've bought cars like that, seller just says the window switch is broken till you find a broomhandle is the only thing holding the window in place.
