Was just looking at you picture of your intake manifold, it looked like the injector seats were dirty like mine. This was from leaking petrol/boost pressure past the injector o rings.
I will get the rings anyway i wont hurt, could this also be causeing my pressure loss fault code.
I don't think so because there isn't anything to read the pressure after the MAP sensor.
Also pressure loss would be minimal
But wouldn't hurt for sure.
Can you get a close up picture of these to be sure
how did you get the map sensor loom to the n/s of the vehicle?? i'm looking at doing this but without the manifold change
actually i think i'm being a tard... i wont need to move it on that arrangement??
never the less i'd be interested to know anyways:confused:
Where idid you get the cooler from and how did the jb weld go if you used it in the end??
Thats my car :confused: You won't need to change manifld thats the standard one.
Great work Phillc :). One of the nicest LC on site. I will be looking through this thread regulary for inspiration haha.
Had a few people comment on your car at work when you popped those bushes round the other day
Should have some wishbones myself in the next few days so i can do both sets at the same time
Those OE bushes feel much better too
Excuse my ignorance,but in list of mods it mentions:-
SAI removed ?
N429 removed ?
Evap system removed ?
What are these?
I have fitted a new Catch tank, i wanted one with two inputs to get rid of the "T" piece and the correct size so i had one custom made it also has a baffle in front of the exit to filter out any oil vapours i am very happy with it, just need to sort some new hose clips out and spray it black.
Looking great Phil, a huge amount of developement has went into this car.
Kudos to you for this.
Great to show guys there are different ways to skin a cat
That looks awesome Phil! One of my favourite engine bays on here.
Thanks very much :D
You put a lot of work into that phil well done.
I just cant leave it alone :whistle: that constant search for bay perfection.
Thanks Willie, coming from you that’s a real complement.
Indeed and you done a fantastic job of it so far.
I just wished there was more products out there for deisels, nearly everything has to be custom made. If you want things done properly it takes time and money.
