Not yet, one of the boys has and is having a few issues with the 2-step because of the misfire counter i think on the ecu. No lift is supposed to be awesome tho, ,massive bangs and holds boost well.
I should be fitting it week saturday, keep you posted.
Its an electronic device which allows no-lift shifting by cutting the ignition for a split second when you depress the clutch. It holds the boost through gear changes as you dont need to let off the throttle. It also has a launch control feature which you can adjust to different revs. Looks like a good bit of kit. There are plenty of videos on youtube for you to have a looksie at......
lol, nice one dave, its gonna be fitted next weekend by the looks of things.
Got a few bits to do, just small things to tidy up/fix. New rocker cover gasket, coil pack wires being tidied and new door panel clips. Fit my new painted cam belt cover and get my harness bar fitted.
Next couple of weeks will see sound deadening removed, passenger side wire tuck, and starting to smooth the engine bay, which will just be removal of plates/brackets etc...
