Small boring update, im fixing all the small things wrong with the car at the moment, so ive picked up new slave and master cylinders for the clutch. My clutch pedal has never been right since i bought the car, causing the pedal to drop almost to the floor on occaision which i have to put my foot behing and pull it out.
interesting trying to do that when driving, and changing gears in heavy traffic isn't? had that same issue with mine....not fun at all![]()
phil do you have spacers on the rear with those RS4 reps on??
im wondering weather they rub at all??
Not anti lag.
Mine has launch control in the sense you can set the desired rpm limit in first and launch at that, and it was flat/WOT shifting. Hence the name WOT Box.
For people who dont know what flat shifting is, its gear changes without lifting the accelerator pedal whilst at WOT.
Some people just buy things for the sake of it not knowing what it is.
