please help still no boost problem!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
was anything done to the car befor ehand or is this just happened out of the blue?
and no boost as in Zero? or 5psi boost
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Have you checked all the vacuum lines yet? Also might be worth having a look at the actuator on the turbo incase it's pooped.:)
djkorky
fresh to death
Oct 29, 2010
58
Ardrossan
I had a similar problem a while ago mate but i had about 12 fault codes stored, turned out to be a fuse!! Is youe EML on? If so check your fses, if i remember correctly its fuse 8 i think, 10 amp. Hope this helps [B)]
B12rky
61
Redcar Cleveland
Right were can i start,
cars not boosting probly only boosting to 10psi so next to no boost, had this problem for a week or so but sick of looking in the engine bay atm so left it for a few days and came back to it today after work, checked all vac pipes for splits and there was nothing checked intercooler pipes for pipes disconnected and found nothing then Checked Actuator it was set at 10 threads from end and adjusted it to 14 threads ( standard 20vt cupra set up, and still made no differance. the n75 valuve is ok asel as put my mates n75 on whitch works fine on my mates and not on mine so its not that, the only thing i can think of is the n249 perhaps the sensor is broke but wen i put it on vag-com nothing came up,
CAN ANYONE HELP
thinking of doing a 249 bypass to see if that sorted the problem ?
IDEAS ANYONE :)
would be more then gratefull
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
It's worth replacing the vac lines bud cause they tend to corrode inside but also does the actuator move freely? Is there any exhaust leaks before the turbo? I'm not very clued up on the petrol turbo motors so no nidea about the n249.
