cupra r rob
165
Cars booked into garage on friday as its misfireing badly and engine lights on. I think its the coil pack but wondered if i can drive it to the garage as it is, or if i need to get it towed.
Any help would be much appreciated, cheers.
Hi There
If its mis-firing, dont drive it far, as you are running unburnt fuel through your CAT. This will cause damage.
If the garage is not far, then you'll be ok, but be sure to drive with minimum throttle, and once the coil pack is done, give the car a bit of hard driving to clear it ;)
