Pressure Drop between Turbo and Throttle Valve (check D.V.!)
May 13, 2007
1,017
Denmark
At the moment, I check for faults before starting the car. Every day, no errors, turn the key and starts the engine, and the "Pressure drop error" is displayed... I let it idle for 20 sec... clear the fault and check for errors again... no faults will then be displayed... if I then stops and starts the engine again...still no errors....
May 13, 2007
1,017
Denmark
You can says is always the "first timer" that makes "pressure drop error"...each morning... when i'm going from work 8 hours later nothing happens... could seem like it's related to the temperature...
sportbilly
thinking out loud
Oct 8, 2001
2,386
in my car
From my experience the pressure drop is a common fault for a few things. You have changed all the obvious items except the n75 which has caused people various problems in the past from limp mode to bouncing boost.
