Problem after fitting new ECU
MarksySeat
Hi All,
My dad has a 1998 Ibiza 1.0. His ECU was fried so he bought another off ebay. Now the immobiliser seems to be shutting the engine down on start up.
Any ideas how to get round this?
William
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
reprogramming the immobiliser
without the SKC code you will need either Vag-Tacho + Vag Com or a Dealer to do it
or send it off to a specialist for an immobiliser defeat/removal
MarksySeat
Ok. Thanks. Any idea how much that might cost?
The old car might not be worth it I'm afraid.
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
Hi All,
William
you need to get the key that from the car you got the ecu from and swap the chip into the key your using at the moment if not your looking on reprogram not sure on cost etc but its much easier and cheaper to swap chips just done it myself
MarksySeat
How do you remove the immobiliser?
I didn't think this was possible?
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
i cant do it myself speaking but i had a golf gt tdi , had to change the clocks fitted new clocks car wudnt start immobilzer diasbled the car , was told by my local garage take it vw to program or remove the chip i took the ecu off the car and sent to guy off ebay he took the immobiler iff and posted it bk for £70 , vw want £200
MarksySeat
Right. On the advice above, I have asked the guy I got the ECU from to get me the key. He is to get back to me. Presumably if all I have to do is change the chip in the key, the part in the ignition barrel is just a reader and doesn't need to be matched to the ECU.
I hope this is right?????
I'll let you know if I get it working.
j.cavo
Aug 6, 2009
229
Liverpool
yes it will just talk to the ecu and tell it that the correct key is in it ive just changed an igntion so i had to swap the chip out my old key into the new key an it works 100%
MarksySeat
j.cavo, based on what you just said, will i not need the ignition as well?
j.cavo
Aug 6, 2009
229
Liverpool
no they key splits into two and you can see the chip inside the key its the chip that needs swaping because i swaped my locks but had to use the chip out my old key so your doing things the opposite way you have a new ecu so u need the chip from the key off the new the ecu but cos ur locks havent changed its new chip into old key and trust me it will work 100%
basically its the chip that talks to the ecu via the transponders so your ignition is turning so all you need is the chip ill try an get a pic for you
