Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Not sure how to search for this. On the turbo intake pipe right at the bottom where it sticks on the turbo, theres a small vacum line connector,
What is that for and is that nesscary?
think from last time i looked at mine it connects on to one of the metal lines some where not sure though. not really much help sure it is needed though
it needs it, my car was in limp mode for ages with no vagcom faults i was pulling my hair out untill i started to strip it down and noticed a loose pipe, if you follow it back its a hard pipe on the right hand side of the rocker cover not sure what it does though
Its part of the evap loss control system, so unless you have put the whole lot in the bin, you will need to reconect it. I bined the full system as have others on here and blanked the take off on the TIP with a small alloy bung.
So you saying the pipe that i blocked up on the trottle body, use that to run the dv of it? is that same thing as the under the inlet mani ?
May run the boost gauge of it
