Ive repaired the faulty light switch, the foglight mechanism was jammed so i freed it and now everything works except leaving home. Il do what you said and factory reset the settings in menu.Absolute LEGEND!!
Got the sensor and switch last August and gave up after trying OBD11 and VCDS on the long coding for about a month.
Spent 5 mins tonight in OBD11 adaptions and the everything worked, except leaving home lights. Factory reset the light settings in the the car and boom, leaving home now works.
Can’t thank you enough for finding this solution!!
I also noticed in the climate control display, the air clima setting doesnt activate or sync, maybe the factory reset might fix this too. Will post back tomorrow. Excited moment lol
EDIT: couldnt wait so i went out and done a factory reset. Everything is working perfect now even the clima
Cant thatnk you guys enough
