Rear wiper removal
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
hhhmmm im bored and off work so going down halfods after a bacon sarnie to get the gromits.
been meaning to do it for a while so may aswell today will take before and after pix for you if you want.?
shantybeater
loving the whoosh
Sep 28, 2007
645
Bournemouth & Brighton
can someone just take pic of the screws im supposed to undo to get the damn thing out? got the boot cover off but not sure where to go from there, and where is the washer hose located in the engine bay?
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
what screws.?
do you mean the bolts to undo the washer motor there is 3 bolts one ontop and two eaither side dont forget to undo the bolt holding the wiper itself under the little flap on the wiper.
i never took the hose off from the engine bay i just blocked it off from the boot end.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
right all done.
before.
after.
bits removed.
the only problem i had was this pinged off from somwhere when i was takeing the plastic cover off
it wasnt until i put it all back on that i realised it was to hold the screw from under the grab handle.
cant be bothered with taking it back off at the moment but will do if it rattles atall.
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
Is there a way of tweeking the rear screen wash spray so the water will come out backwards
ie. hit the car behind you in a traffic jam ?
:D
that there is i have it done ( not intenually) well if you leave the pipe there after removing the wiper i should think that it will just squitrt it then if you cut a hole in the gromit
i don't have mine dewiperd yet :(
Nov 2, 2004
9,335
South Wales
Theres a screw or two in the recessed handle on the plastic inside.
Its pretty easy to do, the worst part is actually pulling the plastic off and replacing it. Mine has never sat right since re-fitting it.
