dave_6
193
Essex
Hi,
Just finished removing my SAI, was getting the incorrect air flow fault on vag com and an EML ! removed the valve and put in a plate. Havent cleared the fault on vag com yet but i'm hoping I wont get the anoying light anymore........
anyway, question is
What shall I do with the 2 circled sensors, at the moment i've just taped them off but should I have them going somewhere....?
The pipe from the valve was going to the sensor I'm holding up before but obviously nothing goes there now
Looking to sell in a months time or so and an EML could be a bit of a pain
Evev with it reoved you will still get the incorrect flow code and light coming on every now and then. You can remove those two sensors aswell. You need to put a 10w 330ohm resistor in their place.
sure some people haven't been getting an EML coming on? will be a bit of a pain when selling it if the light comes on every now and again
Just reset things with vag com so i'll see how long it takes to come back on
cut off the connectors on both and stick a 10w 330 ohm resistor is their place.
as for code, its intermittent, so will come back maybe once a month or something
Will the code always come back, or can it be stopped? Mine pops up a few days after clearing it and has been doing this for the last 3-4 times! It was suggested to me that it will stop coming on after about 3-4 times of clearing it?
whoever said that lied riko...i'm sorry to tell you
the code comes on for the pump, not for the 2 n112 valve you cut off (the ones circled)
the ECu thinks the N112 valves are still connected due to the resistors, however the pump connector is different resistance so throws a code with the 10w 330 ohm.
you'll have to live with the code or somehow measure the resistance
