Dont forget to unplug the airbag wires underneath if you have airbags in the the seats.
And its 4 torx bolts, 2 front, 2 back.
And i think when i did it i may have had to remove some of the plastic trim to get access to them.
Once there out its easy to give them a good clean and to clean the carpets but it is a pain in the arse job so make sure you have good weather and arent rushing.
be careful mate, i took mine out the clean under them and the passanger side doesnt want to line up with the bolt holes again so ive stuck with squeaky chairs and 3 bolts. nitemare
Yep good point
Mine didnt want to line up either so i had to put 3 of the bolts in loosely and then pull it over to get the forth one in and then tighten a bit at a time equaly across all four.
Hope that makes sense :cry:
Dont forget to disconnect battery first and leave for 10 min befor unplugging air bag and dont switch your ignition on your air bag light will stay on and wont turn of till you clear the fault.
