Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
if it happened when you pressed hard or the odd slippy surface that would be the abs working![]()
Yeah the signal needs to be constant, the chunk missing is sending a signal the ECU can't read so flags the fault.
Looks like you need a new wheel hub as I'm not 100% sure if the signal ring is just pressed on or not.
IF the ECU reads that the brakes are applied it cuts most of the power - this is what your dodgy sensor was telling it![]()
But the power was cut with the sensor DISconnected? The power returned (even though it grinds when I pressed the brake pedal) when I plugged it back in and the warning lights went off? Or I am understanding what you're saying wrong lol
Or do you mean if the ECU reads that the ABS is faulty it cuts most power?
