strange.... using a small halfords professional socket set I could get to all the retaining nuts on the ATP one?
When you say small what do you mean? I can't get a socket or spanner in. I'll have a look round Halfords today.
I've asked Star what they used to tighten them up - although I'm not holding my breath for a helpful response.
im taking my atp manni off next week, so definatly keeping a keen eye on this thread
hope CR do a good job for you rob
CR Turbos just phoned me to say the turbo is being collected this afternoon.
I want to take the manifold off and send it off to Zircotec to be thermally coated, or even fit a tubular JBS manifold although I'm still not convinced it won't crack!
why you are not convinced it wont crack Rob, I dont believe there has been any reports of any JBS manifolds cracking
the only report was a possible one cracking, but that was due to worn out engine mounts on an ibiza which was causing too much flex on the downpipe and a leak to occur between the manifold and downpipe and a failure in the gasket I believe
I have.
Feel, AEB engines are longitudnal engines, that THS one is for transverse, if i was to get a transverse mani it would be that THS one, i've seen it, i know someone who has it and has had the ATP one and reckons the quality is the same, if not better.
I have.
you have had a cracked JBS mani? well I am surprised, but JBS refund or replace right?
Well, Turbo Dynamics have come straight back to me with info on the 2 hybrids they do for the K03S fitment, the second one interests me the most (for obvious reasons!), they are both K04's, the first one offers 240-250bhp but the second one offers:
MD445 - K04 turbo with Hi flow K04 compressor wheel, cnc machined compressor housing , large trim K04 turbine wheel, lightening of turbine wheel for faster ‘spool up’, cnc modified turbine housing, ported wastegate, uprated turbine seals. Other ‘blueprinting’ modifications. 12 psi Uprated actuator APPROX 280- 300 BHP. Absolute Maximum recommended boost level – 24-26 P.S.I.
Please Note: This application needs exact engine management settings, free flow exhaust system and front mount intercooler to achieve these horsepower figures, however, the exhaust manifold is the limiting factor in achieving any real worthwhile gains and would need to be changed to get maximum benefit from the turbocharger.
£1250 + VAT
A bolt on K04 capable of 300bhp .......... ! :D Sounds alot like the JBS04 TBH.
CR Turbos have collected my GT2X, they'll have it tomorrow.
The full info sheet is this:
VAG Hybrid Turbochargers
Applications:
VW Golf - Bora – Seat Leon – Skoda –– Audi A3/TT 20V
Fitted with K03S Turbocharger 180Bhp
KKK Turbocharger – Part 5303-970-0052
Vag Part No. – 06A145713D/704T 2001->
Stage1 Stage2
MD349 MD445
Brief Specifications: -
MD349 High flow K04 2275 Spec Compressor wheel, C.N.C. re-profiled compressor housing, 360 degree thrust bearing, modified watercooled bearing housing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified turbine housing, up-rated twin turbine seals. Other ‘blueprinting’ modifications. APPROX 240-250 BHP
Absolute Maximum recommended boost level – 18-20 P.S.I.
Please Note: This turbocharger will fail in the thrust assembly if the maximum boost level recommendations are not strictly adhered to as this unit it not designed to operate beyond these parameters.
MD445 K04 turbo with Hi flow K04 compressor wheel, cnc machined compressor housing , large trim K04 turbine wheel, lightening of turbine wheel for faster ‘spool up’, cnc modified turbine housing, ported wastegate, uprated turbine seals. Other ‘blueprinting’ modifications. 12 psi Uprated actuator APPROX 280- 300 BHP
Please note: - All specifications are for reference purposes only and are subject to change by Turbo Dynamics Ltd. without prior notice. All boost pressure recommendations are subject to engine condition and preparation. Modifications to the engine can affect the performance and reliability of the turbocharger and the related performance figures. For further information please talk to our technical staff who may refer you to one of our recommended tuners.
APLICATION : 180 BHP Turbo
Retail Price List 2008
Part No. List Price
MD349 £1050.00
MD445 £1250.00
Options: - All the above turbochargers can be fitted with any of the listed options by request/ special order and at extra cost, if not part of the standard specification. One off specifications and turbo matching also available.
Modified compressor inlet duct
Cut back turbine blades
Modified turbine housing internals (porting)
4. Uprated actuators
All prices are in Pounds Sterling (UK), net ex-works and supersede all previous prices.
All prices are subject to VAT at the current rate.
The prices listed are for turbochargers supplied on an exchange basis. If required on an outright
basis (no old unit available), please ask for quotation.
Turbo Dynamics Limited reserves the right to revise, change or modify part numbers, specifications and prices of listed items without notice.
The listing of a price for a particular part number does not guarantee availability.
I have.
Yeah, I'm fairly sure the one A&M were selling was off a A4. I'm not positive that it kept the turbo in the same position (but would've thought so).
But it might be worth a look.
But, the THS one is a pretty good price - I recognise it from somwhere, and ISTR that reviews were positive.
