Rubber on brake peddle
fester
Searched but could not find the answer,any one changed the crap(keep falling off) :doh: peddles for anything a bit more solid,i.e. bolt ons if poss.Cheers
Pabs
5,936
Basingstoke
the audi tt pedals that i fitted are really quite good - the accelerator pedal gets glued to the original plastic/rubber one tho. The other two replace the std ones.
Ebay usually has the Cupra R ones going - but tend to rocket over £30.
craigomills
Candy White FR TDI 170
Mar 31, 2005
195
Derby
the clutch pedal in mine is lethal.
its too easy to slip off with wet feet!!!
what a pain in the ass!
Jonny
slightly insane monkey
Jul 5, 2005
769
South Wales
My brake pedal cover came off while I was driving home after picking the car up from the dealer, the rubber bit that goes through the hole in the pedal wasn't fitted properly...
If you check they're located properly and fitted all the way round you shouldn't have a problem with them coming off - they're bit of a pain to fit, but they're a pretty secure & tight fit!
If when fitted correctly it / they keep coming off, check the rubber around the edge for damage / splits. Should be able to get replacement rubbers pretty cheap.
fester
Just back from Sheffield and still on,but for peace of mind would still prefer something that's bolted/screwed on.Stuck in outside lane of M1 imagine it flirting off then,it was bad enough doing it at about 30mph coming up to red traffic lights!!!
leonlad
1,219
73
london
you had to glue it because you have a LHD accelerator pedel and not a RHD
rhd fit stright on
JmZ
ZZZooooommmmmmm!
Nov 20, 2002
259
around and about
I find it depends more on what I am wearing on my feet with the TT pedal rubbers as to how slippery they are.
Wet soled trainers with non-marking soles are the worst of the lot. On standard pedals I had no chance, at least on the TT pedals set, it is 50/50 rubber/metal so I can get some grip!
I got the Curpa R one off Awesome GTI a few weeks back
VAG part numbers are
For the Gas Pedal (depends on your pedal Box)
1M1 721 535 A
or
1M2 721 535
For the Brake
1M0 721 275
For the Clutch
1M0 721 961 A
used to have the TT pedal on my Corrado, not sure on the number though
