AdrianL
74
Batley, W Yorkshire
Hi guys,
So I went on a rolling road today as I thought it may be useful to diagnose the issue I've been having with the fault code issue (P0328 - G61 Signal Too High). Follow on from this thread: http://www.seatcupra.net/forums/showthread.php?t=396213
Anyway. I asked for the air/fuel ratio to be looked at and he said that's it's running VERY lean. The power output was good (perhaps a tad low?) - 189 at the wheels so approx 217bhp at the flywheel.. which is 4bhp down from what the book says? 221bhp?
The following performance mods are installed:
Cobra Sport Cat Back Exhaust
K&N Panel Filter.
Now I found a list of things to check:
Running Lean – VAC Leak, MAF, O2 Sensor, Fuel Filter
but are there any issues that are most likely going to be the issue? I know K&N filters can be bad for the MAF due to being oiled up... is this the same case for panel filter and potentially a cause of running lean?
Thanks in advance..
Adrian
It will most likely be a split pipe in the PCV system or the valve under the inlet manifold in the PVC pipe where it changes diameter has broken , or broken dipstick tube . Any ingress of air into the system which operates the crank case in a state of partial vacuum results in a weak mixture.
Thanks Wilderides, you always give a detailed response. I'm going to do some logging first that will hopefully narrow things down for me.
How would I go about checking a broken dipstick tube? would it be visibly obvious? The dip stick sits in the holder fine, but are you saying any cracks / damage at all could cause a problem?
Thanks,
Adrian
Yeah .......... it cracks and falls to bits .......... usually breaks off and wobbles about loose . The valve in the pvc under inlet mani is hard to detect but it is inside the pipe and basically it wears out and sticks perminant open or shut . You can check for this by clamping the pvc pipe after the valve with mole grips to shut off the pipe and see if symptoms go or stay.
I used to get a trade mechanics mag with a help column for other techs and 1.8t weak mix was in there practically every week . There are so many pipes to check on the pcv etc and a leak on any can do it !
Haha, brilliant. Well at least I'm at safe hands with some of the knowledgeable people like yourself on the forum. Should have more news tomorrow night!
Well unfortunately the software I have will only log from 001 to 025, not sure if logging those are any good?
I'm going to spray all the pipes below plus the dip stick with electrical cleaner tomorrow, so I'll post up how I'm getting on tomorrow.
Cheers,
Adrian
If it is running lean, scanning it with vagcom (just error code scanning) will say it runs lean. This is usually from "false" air being drawn. The most common culprit is the PCV system, check all (!!!) pipes from the PCV system, also check the Jet Suction Pump, this one is known to fail (read: leak) as well.
Does anyone know if the diagram above shows all the areas of the PCV system I need to check? I sprayed what I could see tonight in the dark with some electrical cleaner but didn't hear any change in RPM... but I may need to have a second go when I can see what I'm doing.
I've also tried to capture what I can with the VAG-COM but not sure if it's anything useful as it's only the limited version. I may have to pay up $100 for the registered version..
This was a second gear pull, from 2500 -> Redline.
Code:
	Group A:	'001				Group B:	'002				Group C:	'003
		Engine Speed	Coolant	Lambda Control	Basic Setting		Engine Speed	Engine Load	Injection Timing	Mass Air Flow		Engine Speed	Mass Air Flow	Throttle Valve Angle	Ignition
	TIME	(G28)	Temperature (G62)	Bank 1	Requirements	TIME	(G28)			Sensor (G70)	TIME	(G28)	Sensor (G70)		Timing Angle
Marker	STAMP	 /min	°C	%		STAMP	 /min	%	 ms	 g/s	STAMP	 /min	 g/s	%	 °BTDC
	0.01	760	77	0	1111110	0.3	720	21.1	2.04	2.72	0.6	760	2.72	1.6	3
	0.9	720	77	0	1111110	1.2	720	21.1	2.04	2.72	1.51	760	2.75	2	3.8
	1.81	720	77	0.8	1111110	2.11	720	21.1	2.04	2.72	2.41	760	2.81	2	1.5
	2.71	720	77	0	1111110	3.01	760	21.8	2.04	2.83	3.33	760	2.81	2	0.8
	3.62	720	77	3.9	1111110	3.92	760	21.1	2.04	2.75	4.22	720	4.25	4.7	22.5
	4.52	960	77	1.6	1100010	4.82	1320	42.9	3.74	10.25	5.14	1360	10.44	7.5	21.8
	5.43	1240	77	-0.8	1101010	5.74	1240	48.1	4.08	12.14	6.04	1200	12.22	8.6	21
	6.33	1160	77	1.6	1101010	6.63	1160	53.4	4.76	12.44	6.95	1440	20.33	15.7	18
	7.25	1680	77	0	1100010	7.55	1920	63.9	5.44	22.69	7.85	2160	22.19	13.7	27
	8.15	2360	77	-9.4	1101000	8.44	2320	24.8	2.04	6.42	8.76	2160	5.81	4.7	9
	9.05	2040	77	0	1100000	9.36	1720	36.8	3.4	13.33	9.66	1680	16.94	11.4	27
	9.96	1720	77	-6.3	1101010	10.27	1840	64.7	5.78	24.22	10.57	1920	25.86	16.9	19.5
	10.87	2040	77	0	1101000	11.17	2120	52.6	4.42	20.72	11.47	2200	20.86	12.9	28.5
	11.77	2280	77	0	1101000	12.08	2360	52.6	4.42	24.17	12.38	2440	24.22	13.7	29.3
	12.68	2520	77	0.8	1101000	12.98	2520	22.6	2.04	9.06	13.28	2520	7.61	5.9	36
	13.58	2520	77	-4.7	1101000	13.89	2520	17.3	1.7	8.22	14.19	2520	8.64	6.7	36
	14.49	2520	77	-5.5	1101000	14.79	2520	24.8	2.38	12.56	15.09	2520	12.81	8.6	34.5
	15.39	2520	77	1.6	1101000	15.7	2560	25.6	2.38	12.83	16	2560	12.72	8.6	34.5
	16.3	2560	77	0.8	1101000	16.6	2560	25.6	2.38	12.67	16.9	2560	12.86	8.6	34.5
	17.19	2560	77	1.6	1101000	17.5	2560	25.6	2.38	12.44	17.8	2560	12.61	8.6	34.5
	18.11	2560	77	2.3	1101000	18.41	2560	25.6	2.38	12.72	18.71	2560	12.58	8.6	34.5
	19.01	2560	77	0	1101000	19.32	2520	26.3	2.38	12.97	19.62	2520	12.92	8.6	34.5
	19.92	2520	76	-0.8	1101000	20.22	2520	26.3	2.38	12.58	20.52	2600	44.67	81.6	24
	20.82	2760	77	0	1100000	21.13	2920	110.5	10.54	74.11	21.42	3160	102.64	100	16.5
	21.73	3440	76	1.6	1100000	22.03	3800	186.5	18.02	137.08	22.33	4080	135.47	100	4.5
	22.64	4440	76	3.1	1101000	22.94	4720	162.4	14.96	141.86	23.24	5040	154.83	100	16.5
	23.54	5320	76	3.9	1101000	23.84	5600	157.1	14.62	167.97	24.14	5840	171.94	100	18.8
	24.45	6120	76	3.9	1101000	24.75	6320	149.6	13.94	177.72	25.05	6560	171.11	100	18.8
	25.36	6520	76	0	1110000	25.65	6040	13.5	1.36	7.17	25.95	5320	9.36	8.6	4.5
	26.26	4600	76	0	1110000	26.56	4600	11.3	0	8.92	26.86	4480	10.11	7.1	4.5
	27.16	4440	76	0	1110000	27.46	4000	12.8	0	9.61	27.75	3520	8.94	6.3	3
	28.06	3200	76	0	1110000	28.36	3120	13.5	0	8.08	28.66	3000	7.33	5.1	3
	28.97	2960	76	0	1110000	29.26	2920	12.8	0	7.61	29.56	2920	7.64	5.5	1.5
	29.88	2880	76	0	1110000	30.18	2880	12.8	0	7.5	30.48	2880	7.25	5.1	1.5
	30.77	2840	76	0	1110000	31.07	2840	12.8	0	7.36	31.37	2840	7.19	5.1	1.5
	31.69	2800	76	0	1110000	31.98	2800	12.8	0	7.19	32.29	2760	7.44	5.1	1.5
	32.59	2760	76	0	1110000	32.89	2680	13.5	0	7.14	33.18	2560	6.94	4.7	0.8
	33.49	2480	76	0	1110100	33.79	2400	12.8	0	6.31	34.1	2320	6.03	4.3	0.8
	34.39	2240	76	0	1110100	34.69	2160	13.5	0	5.56	34.99	2080	5.42	3.9	3
	35.3	1960	75	0	1110110	35.6	1880	13.5	0	4.86	35.9	1760	4.67	3.1	6.8
	36.2	1640	75	0	1110110	36.5	1360	13.5	0	3.58	36.81	1080	5.58	4.3	24.8
	37.11	1000	75	0	1110110	37.42	960	21.8	2.04	3.83	37.71	920	3.81	2.7	2.3
	38.01	880	75	0	1110110	38.31	840	20.3	2.04	3.36	38.62	800	3.08	2	0.8
	38.92	760	75	4.7	1111110	39.22	760	20.3	2.04	2.94	39.52	760	3	2	0.8
	39.82	760	75	1.6	1111110	40.12	760	20.3	2.04	2.97	40.43	720	2.92	2	3.8
	40.73	720	75	-1.6	1111110	41.03	720	20.3	2.04	3.06	41.33	760	2.94	2	1.5
	41.63	720	75	-2.3	1111110	41.93	760	21.1	2.04	3.08	42.24	760	3.08	2	0.8
	42.54	760	75	-2.3	1111110	42.85	720	21.1	2.04	3.06	43.14	720	3.11	2	0.8
Excel document here: https://dl.dropboxusercontent.com/u/18331202/carstuff/SeatLeonCupraR/2ndGearPull.xlsx
Anything useful?
Thanks,
Adrian
Oooh, just found this amazing guide! http://audi.service-bg.com/Articles/usermanuals/Audi-A4_A6_A8/1.8T Troubleshooting Guide.pdf
Seems to cover some good issues.. and tells you what blocks to measure :). So I'm sure I'll be back with "What do all these numbers mean!?" soon.... think I'll do it tomorrow night.
Brilliant, getting mine mapped at the end of the month so want to solve as many of these issues as possible, Typically the bloody emmsions light has come on this week.
Garage that fitted the clutch today looked and said it was something to do with the Turbo inlet so going to examine the TIP Sat but this little guide will help no end.
Got new MAF and coilpacks already just need to get a smoke test done to find any leaks
^^ No probs :)
Does anyone think the MAF reading looks too high at around 6500rpm? There are two readings shown in the excel doc... one is 171g/s and the other is 177g/s. In the document I linked to before it said it should be 170g/s on a CHIPPED car? Only performance mods on this are cat back exhaust and panel filter.....?
replace the valve labelled 5 in the parts diagram a few posts back ....... it wears out and leaks vacuum when it should not
So I've had a look... and the valve appears to be blanked off!?.. I also found a slight pipe with a kink on it? (it's not on the diagram above) anything significant? Don't mind the wet patches, it's where I had been spraying electrical cleaner.
Blocked off PCV valve?:
Kinked pipe under the alternator:
Thanks,
Adrian
I've bought a VCDS-Lite licence tonight so hopefully that will be up and running soon so that I can get some figures posted up tomorrow...
Thanks,
Adrian
OK, here you go.. hope this helps..
So idling, then 1500rpm, 2000rpm, 2500rpm for blocks 001, 031 and 118:
Code:
Thursday	6	March	2014	22:42:51
1ML 906 032 A		1.8l R4/5VT         0002
	Group A:	'001				Group B:	'031				Group C:	'118
		Engine Speed	Coolant	Lambda Control	Basic Setting		Lambda Control	Lambda Control	Bin. Bits	Bin. Bits		Engine Speed	Intake Air	Boost Pressure	Boost Pressure
	TIME	(G28)	Temperature (G62)	Bank 1	Requirements	TIME	Bank 1 (actual)	Bank 1 (specified)			TIME	(G28)	Temperature (G42)	Control (N75)	(actual)
Marker	STAMP	 /min	°C	%		STAMP					STAMP	 /min	°C	%	 mbar
	0.01	760	75	3.1	111110	0.29	1.008	1	        	        	0.6	760	45	0	1000
	0.9	760	75	-0.8	111110	1.2	1.008	1	        	        	1.5	720	45	0	1000
	1.8	760	75	-1.6	111110	2.1	0.992	1	        	        	2.41	760	45	0	1000
	2.71	720	75	-2.3	111110	3.01	0.992	1	        	        	3.35	760	45	0	1000
	3.61	720	75	-2.3	111110	3.91	1	1	        	        	4.22	760	45	0	1000
	4.52	720	75	1.6	111110	4.83	1	1	        	        	5.12	720	45	0	1000
	5.42	720	75	1.6	111110	5.72	1	1	        	        	6.03	720	45	0	1000
	6.33	720	75	1.6	111110	6.63	1.008	1	        	        	6.93	720	45	0	1000
	7.23	760	75	1.6	111110	7.53	1	1	        	        	7.84	720	45	0	1000
	8.15	760	75	-3.1	111110	8.44	0.992	1	        	        	8.74	760	45	0	1000
	9.04	760	75	-3.9	111110	9.35	0.992	1	        	        	9.65	760	45	0	1000
	9.95	720	75	-3.9	111110	10.25	0.992	1	        	        	10.55	760	45	0	1000
	10.85	720	75	-3.9	111110	11.16	1	1	        	        	11.46	720	45	0	1000
	11.76	720	75	0	111110	12.07	1	1	        	        	12.36	760	45	0	1000
	12.66	720	75	0	111110	12.98	1	1	        	        	13.27	720	45	0	1000
	13.57	760	75	0	111110	13.88	1	1	        	        	14.17	720	45	0	1000
	14.47	760	75	-0.8	111110	14.78	1.008	1	        	        	15.08	720	45	0	1000
	15.39	760	75	-4.7	111110	15.68	1.008	1	        	        	15.98	760	45	0	1000
	16.28	760	75	-3.9	111110	16.59	1.008	1	        	        	16.89	760	45	0	1000
	17.19	760	75	-3.9	111110	17.49	0.992	1	        	        	17.8	720	45	0	1000
	18.09	720	75	-4.7	111110	18.4	1	1	        	        	18.71	720	45	0	1000
	19	720	75	0	111110	19.31	1	1	        	        	19.6	720	45	0	1000
	19.91	720	75	0	111110	20.21	1	1	        	        	20.51	720	45	0	1000
	20.81	720	75	-0.8	111110	21.11	1.008	1	        	        	21.41	720	44	0	1000
	21.72	760	75	0	111110	22.02	1.008	1	        	        	22.32	720	44	0	1000
	22.62	760	75	-3.9	111110	22.92	1.008	1	        	        	23.22	720	44	0	1000
	23.53	760	75	-4.7	111110	23.83	0.992	1	        	        	24.14	760	44	0	1000
	24.43	720	75	-4.7	111110	24.73	0.992	1	        	        	25.03	760	44	0	1000
	25.34	720	75	-4.7	111110	25.64	0.992	1	        	        	25.94	720	44	0	1000
	26.24	720	75	0	111110	26.54	1	1	        	        	26.84	760	44	0	1000
	27.15	720	75	0	111110	27.45	1.008	1	        	        	27.75	720	44	0	1000
	28.05	720	75	0	111110	28.36	1.008	1	        	        	28.66	720	44	0	1000
	28.96	760	76	0	111110	29.27	1.008	1	        	        	29.56	720	44	0	1000
	29.86	760	75	-3.9	111110	30.16	1.008	1	        	        	30.47	760	44	0	1000
	30.77	760	76	-3.9	111110	31.07	1	1	        	        	31.37	760	44	0	1000
	31.68	760	76	-3.9	111110	31.97	1	1	        	        	32.28	760	44	0	1000
	32.58	720	76	-3.9	111110	32.88	1	1	        	        	33.18	760	44	0	1000
	33.48	720	76	0.8	111110	33.78	1.008	1	        	        	34.1	760	44	0	1000
	34.39	720	76	0.8	111110	34.69	1.008	1	        	        	34.99	720	44	0	1000
1	35.29	720	76	0.8	111110	35.6	1.008	1	        	        	35.9	720	44	0	1000
	36.2	760	76	0.8	111110	36.51	1.008	1	        	        	36.8	720	44	0	1000
	37.1	760	76	-3.1	111110	37.41	1	1	        	        	37.71	1000	44	0	1000
	38.01	1320	76	-4.7	101110	38.31	0.922	1	        	        	38.61	1480	43	0	1000
	38.91	1480	76	-15.6	101110	39.21	0.969	0.961	        	        	39.53	1440	42	0	1000
	39.83	1440	76	-10.2	101110	40.13	0.984	0.953	        	        	40.42	1440	42	0	1000
	40.72	1440	76	-7	101110	41.03	0.961	0.953	        	        	41.33	1480	42	0	1000
	41.63	1480	75	-7	101110	41.94	0.953	0.953	        	        	42.24	1480	42	0	1000
	42.53	1480	75	-6.3	101110	42.84	0.961	0.953	        	        	43.14	1480	42	0	1000
	43.45	1480	75	-5.5	101110	43.75	0.953	0.953	        	        	44.04	1520	42	0	1000
	44.34	1560	75	-5.5	101110	44.65	0.953	0.953	        	        	44.96	1560	42	0	1000
	45.25	1600	75	-5.5	101110	45.55	0.961	0.953	        	        	45.86	1600	42	0	1000
	46.16	1640	75	-4.7	101110	46.47	0.953	0.953	        	        	46.76	1640	41	0	1000
	47.06	1680	75	-5.5	101110	47.36	0.953	0.953	        	        	47.66	1680	41	0	1000
	47.96	1680	75	-5.5	101110	48.27	0.953	0.953	        	        	48.57	1680	41	0	1000
	48.88	1680	75	-4.7	101110	49.18	0.953	0.953	        	        	49.47	1720	41	0	1000
	49.78	1720	75	-5.5	101110	50.09	0.953	0.953	        	        	50.38	1680	41	0	1000
	50.68	1680	75	-5.5	101110	50.98	0.969	0.953	        	        	51.29	1600	40	0	1000
	51.6	1600	75	-3.1	101110	51.89	0.961	0.953	        	        	52.2	1600	40	0	1000
	52.5	1600	75	-3.9	101110	52.8	0.938	0.953	        	        	53.09	1600	40	0	1000
	53.4	1600	75	-4.7	101110	53.71	0.953	0.953	        	        	54.01	1600	40	0	1000
	54.31	1560	75	-4.7	101110	54.61	0.953	0.953	        	        	54.91	1560	40	0	1000
	55.22	1560	75	-3.9	101110	55.52	0.953	0.953	        	        	55.81	1560	40	0	1000
	56.11	1560	75	-4.7	101110	56.41	0.945	0.953	        	        	56.72	1560	40	0	1000
	57.02	1560	75	-5.5	101110	57.33	0.953	0.953	        	        	57.63	1560	40	0	1000
	57.92	1560	75	-4.7	101110	58.23	0.953	0.953	        	        	58.53	1560	40	0	1000
	58.84	1560	75	-5.5	101110	59.14	0.961	0.953	        	        	59.43	1560	40	0	1000
	59.73	1560	75	-4.7	101110	60.04	0.953	0.953	        	        	60.35	1560	40	0	1000
	60.65	1560	75	-5.5	101110	60.95	0.953	0.953	        	        	61.24	1560	40	0	1000
	61.54	1560	75	-4.7	101110	61.85	0.953	0.953	        	        	62.16	1560	40	0	1000
2	62.46	1560	75	-5.5	101110	62.76	0.953	0.953	        	        	63.05	1560	40	0	1000
	63.35	1600	75	-5.5	101110	63.66	0.945	1	        	        	63.96	1720	40	0	1000
	64.26	1840	75	-9.4	101010	64.56	0.977	1	        	        	64.86	1920	39	0	1000
	65.16	2000	75	-9.4	101000	65.47	1.008	1	        	        	65.78	2040	39	0	1000
	66.08	2080	74	-11.7	101000	66.37	1.008	1	        	        	66.68	2120	39	0	1000
	66.98	2160	74	-10.2	101000	67.28	1.008	1	        	        	67.59	2160	39	0	1000
	67.89	2160	74	-10.9	101000	68.19	1.016	1	        	        	68.49	2160	39	0	1000
	68.78	2120	74	-8.6	101000	69.09	1.023	1	        	        	69.39	2120	39	0	1000
	69.7	2080	74	-3.9	101100	70	1	0.961	        	        	70.3	2080	39	0	1000
	70.6	2080	74	-4.7	101100	70.91	0.969	0.953	        	        	71.2	2080	39	0	1000
	71.51	2080	74	-4.7	101100	71.81	0.945	0.953	        	        	72.11	2080	39	0	1000
	72.4	2080	74	-6.3	101100	72.72	0.961	0.961	        	        	73.02	2080	39	0	1000
	73.32	2080	74	-11.7	101100	73.62	1	1	        	        	73.91	2040	39	0	1000
	74.22	2040	74	-5.5	101100	74.53	0.977	0.953	        	        	74.82	2040	39	0	1000
	75.13	2040	74	-4.7	101100	75.43	0.945	1	        	        	75.73	2080	39	0	1000
	76.03	2040	74	-10.9	101100	76.33	1.016	1	        	        	76.63	2040	39	0	1000
	76.93	2000	74	-5.5	101100	77.24	0.992	0.953	        	        	77.54	2040	39	0	1000
	77.83	2040	73	-3.9	101100	78.14	0.938	0.953	        	        	78.45	2040	39	0	1000
	78.75	2080	74	-5.5	101100	79.05	0.953	0.953	        	        	79.35	2080	39	0	1000
	79.65	2080	74	-4.7	101100	79.96	0.953	0.953	        	        	80.25	2080	39	0	1000
	80.55	2080	74	-5.5	101100	80.86	0.953	0.969	        	        	81.16	2080	39	0	1000
3	81.47	2080	74	-9.4	101100	81.77	0.992	1	        	        	82.07	2040	39	0	1000
	82.37	2040	74	-2.3	101100	82.66	0.961	0.961	        	        	82.97	2080	39	0	1000
	83.27	2120	74	-10.9	101000	83.58	1.008	1	        	        	83.87	2240	39	0	1000
	84.17	2280	74	-6.3	101000	84.48	1.016	1	        	        	84.77	2360	39	0	1000
	85.09	2360	74	-5.5	101000	85.38	0.992	1	        	        	85.69	2400	39	0	1000
	85.99	2400	74	-5.5	101000	86.29	0.992	1	        	        	86.59	2400	38	0	1000
	86.9	2400	74	-4.7	101000	87.2	0.992	1	        	        	87.5	2440	38	0	1000
	87.79	2480	74	-8.6	101000	88.1	0.992	1	        	        	88.4	2480	38	0	1000
	88.7	2520	74	-7.8	101000	89.01	1	1	        	        	89.31	2520	38	0	1000
	89.6	2520	74	-8.6	101000	89.91	1.008	1	        	        	90.21	2560	37	0	1000
	90.52	2560	74	-7.8	101000	90.82	1.008	1	        	        	91.12	2600	37	0	1000
	91.42	2600	74	-3.1	101000	91.72	1.008	1	        	        	92.02	2680	37	0	1000
	92.33	2680	74	-2.3	101000	92.63	0.992	1	        	        	92.93	2680	37	0	1000
	93.23	2680	74	-3.1	101000	93.53	0.992	1	        	        	93.83	2600	37	0	1000
	94.14	2560	74	-1.6	101000	94.44	0.992	1	        	        	94.74	2480	37	0	1000
	95.04	2480	74	-4.7	101000	95.34	0.984	1	        	        	95.65	2440	37	0	1000
	95.95	2480	74	-5.5	101000	96.25	0.992	1	        	        	96.54	2520	37	0	1000
	96.85	2520	74	-7	101000	97.15	0.992	1	        	        	97.46	2320	37	0	1000
	97.75	2000	74	0	110100	98.05	1.991	1.047	        	        	98.36	1320	37	0	1010
	98.65	1160	74	0	110110	98.96	1.616	0.961	        	        	99.26	1040	38	0	1000
	99.56	960	74	1.6	111110	99.86	1.031	1	        	        	100.16	840	39	0	1000
	100.46	800	75	4.7	111110	100.76	0.992	1	        	        	101.07	760	39	0	1000
4	101.37	760	75	2.3	111110	101.67	0.984	1	        	        	101.97	760	39	0	1000
	102.27	760	75	-3.1	111110	102.57	0.992	1	        	        	102.88	760	39	0	1000
	103.18	760	75	-3.1	111110	103.48	1	1	        	        	103.78	760	39	0	1000
	104.08	760	75	-2.3	111110	104.38	1.008	1	        	        	104.69	760	40	0	1000
	104.99	720	75	-2.3	111110	105.29	1.008	1	        	        	105.59	760	40	0	1000
	105.89	760	75	2.3	111110	106.21	1	1	        	        	106.5	760	40	0	1000
	106.8	760	75	2.3	111110	107.1	1.008	1	        	        	107.4	760	40	0	1000
	107.7	760	75	2.3	111110	108.01	1.008	1	        	        	108.31	760	40	0	1000
	108.61	760	75	2.3	111110	108.91	1.008	1	        	        	109.21	760	40	0	1000
	109.51	760	75	-1.6	111110	109.82	1	1	        	        	110.12	760	40	0	1000
	110.42	760	75	-1.6	111110	110.72	1	1	        	        	111.02	760	40	0	1000
	111.32	760	75	-1.6	111110	111.64	0.992	1	        	        	111.93	760	40	0	1000
