I'm curious, why do you believe it should be free?...hopefully you can get it sorted without putting money into Seats pockets for something that should be free anyway!
I think the update you are talking about is for MIB2 sat nav unit.
Mine is a MIB1
Sorry for being dumb! Would I be able to update mine then? What’s the diff between MIB 1 and MIB 2??
This is a link to the version of maps that works for my Navi System: http://navigation.com/cms/page.leon6P0/en_GB/HEREEMEA/GBP
Backup your current SD card, Download the files you want, delete all files from your SD card, then copy the new files onto the SD card. There’s a file you copy from your originals SD card backup which allows you to use the new files - once I’m home, I’ll verify the file name for certain. It’s worked every time for me.
Just downloaded the latest version from above site and followed the instructions, my car is coming up saying Navigation Database Unavailable' any ideas what I may have missed?
Did you copy the original OVERALL.NDS file to the SD card?
Hopefully you took a backup of the original SD card first
The file is located in maps\EEC\EEC_WLD\
Just copy it from the backup and overwrite the one that will be on the SD card from the updated files.
The general consensus on here seems to be that it is physically possible to swap head units but you need dealers to get them to work and the cost is pretty prohibitive
It's my understanding that the genuine ones have a code in the case this needs coded to your unit to work.
If paddy has updated his,you may not need to buy a thencsrd at all
Hi, re your above . I have a brand new sd card v7. It was unopened. I tried to use it on my 2016 Leon but it did not work at all. You mention a code in the box, where about is this to be found?. Have noticed that the v7 is a tom tom version where as the original is different.It's my understanding that the genuine ones have a code in the case this needs coded to your unit to work.
How do you know which version you have?
