what mods you got smoki333
Be honest is it really worth spending £200 and the effort on a k03s or shall i just save up for a gt2x
Thats upto you at the end of the day mate, only reason im not going gt2x now is the fact of the fitting cost plus mapping. If i could fit it myself i proberly would. Lokking at about the £1500 mark and im not prepared to pay that on top of all the money i have spent so far. So water/meth and a good possibility of a jabba map to see the best from my k03s setup.
I feel ive had to do a fair bit of setting stg2 up myself adding timing etc... to get the results i did but that might not be pure fact, but somthing certinatly wasnt right on the day of the JKM RR day i went to in the summer.
Jay has basicly the same as me but with differant branded mods.
cheers benny just want abit more top end as you no the k03 tails off very early so looking at other options, would like to go down the k03s route if its going pull alot better up the rev range
Depends how much you want to spend really, I didnt take much notice but after the RR day saturday apprently there was a huge differance between my k03s setup and dan cupra R`s setup when we both blasted down the bypass. Only thing he doesnt have is the DP/sports cat.
Cheers for posting that jay, Although they are pretty differant your also getting a slight dip in power at around the 3000rpm stg then picking back up, im not sure if its somthing to really worry about or not. At the moment im putting mine down to the fact ive cranked my WG a fair bit as it didnt show that drop before, and cranking the WG hence that bit more boost could make the ECU have a wobbly then pick back up. I wouldnt mind sombody elses opinion on that.
Side by side i reckon they would be pretty much on par.
Off topic here, Jay do you get much scubbage with how low your car is as thats about the height i would like mine.
Yea i noticed the little dip too, but not noticeable when driving.
No scrubbage at all mate with the ride height, its at that height that if the front splitter scraps i know im pretty close e.g going over speed humps, as you saw the front was close on the rollers
4up not much probs, only if i hit a really bad pot hole but i tend to dodge everything lol:cartman:
you havent got a dyno run when you was on your old ko3 turbo have you benny just to compare
I have one with just the remap with no mods, or i have one with all mods without the k03s which one would you prefere? Although the k03 with mods is estimated flywheel power 224bhp which i think is a little OTT.
Have you been in a k03s ibiza before? if not see if you can.
I personally think a well setup k03s ibiza is quick enough for the road but then there is always the need for more power, i sometimes struggle to get the power down with k03s 230bhp, coilovers and Pirelli's in the dry, wet conditions even damp and your just spinning.
So if i went BT, i'd probably look into getting a LSD.
you say more top end?
Is that speed, as a ko3s will pull 120+ so easy and will touch 140 maybe even more obviously on a track ;)
Just my 2 pence.
with all mods bar k03s please mate
when i say top end i mean my ko3 runs out off puff around 4k ish so just wanted a turbo you can still feel pulling upto about 6 k really, not into top speed runs dont want to lose my licence ;)
Give me 20mins mate and ill geti it up,
Just a had a quick look at some 115 logs and the k03s starts to tail off requsted boost around the 5.5k mark.
by the look of it mine tails off at 4.6k mark got logs below
3rd gear run by the way plus the rates are probably crap boost and timing set to 8/6
Group A: '115 Group B: '020 Group C: Not Running
RPM Load Absolute Pres. Absolute Pres. Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME TIME
MARKER STAMP /min % mbar mbar STAMP CF CF CF CF STAMP
0.01 1600 88 1490 1200 0.6 0 0 0 0
1.13 1840 102.3 1740 1400 1.73 0 0 0 0
2.24 2120 119.5 2070 1600 2.84 0 0 0 0
3.43 2480 146.6 2160 1900 4.03 0 0 0 0
4.53 2880 168.4 2180 2200 5.04 0 0 0 0
5.64 3320 173.7 2200 2260 6.3 0 0 0 0
6.85 3800 167.7 2200 2240 7.45 0 0 0 0
8.05 4240 163.2 2180 2130 8.54 0 0 0 0
9.15 4600 154.1 2120 2010 9.75 3.8 0 0 0
10.34 4920 145.9 2080 1890 10.85 3.8 0 0 0
11.44 5200 137.6 2050 1800 12.14 3.8 0 0 0
12.78 5520 128.6 2020 1730 13.35 3 0 0 0
13.85 5720 123.3 1970 1650 14.44 3 0 0 0
14.95 5920 118.8 1950 1590 15.55 3 0 0 0
16.14 6120 94.7 1920 1240 16.74 3 0 0 0
It tails off at 4.6k but it tails off alot more quickly than k03s heres my logs off 115 to compare. And my graph from storm almost a year ago:wtf:
Code:
	Group A:	'115
	TIME
	0	1840	105.3	1830	1440
	0.35	1920	110.5	1940	1500
	0.75	2000	116.5	2040	1570
	1.15	2080	123.3	2060	1660
	1.55	2160	130.8	2080	1750
	1.95	2280	142.9	2100	1880
	2.35	2400	156.4	2140	2050
	2.75	2520	171.4	2170	2240
	3.15	2640	187.2	2180	2450
	3.55	2760	191.7	2190	2530
	3.95	2880	191.7	2190	2540
	4.46	3040	191.7	2180	2540
	4.86	3120	191.7	2170	2540
	5.26	3280	191.7	2170	2540
	5.66	3400	191.7	2160	2530
	6.06	3480	191.7	2150	2530
	6.46	3600	191.7	2150	2520
	6.86	3720	191.7	2160	2500
	7.26	3840	191.7	2160	2480
	7.66	3920	191.7	2160	2430
	8.05	4040	189.5	2170	2400
	8.46	4160	184.2	2140	2340
	8.96	4280	179.7	2140	2270
	9.36	4360	177.4	2130	2230
	9.87	4440	174.4	2120	2190
	10.27	4560	172.2	2120	2140
	10.67	4680	169.9	2120	2100
	11.16	4760	169.2	2120	2080
	11.66	4880	170.7	2120	2080
	12.16	4960	169.2	2120	2080
	12.56	5040	168.4	2120	2060
	12.96	5120	169.2	2120	2070
	13.36	5200	168.4	2110	2080
	13.76	5280	168.4	2080	2080
	14.25	5360	165.4	2080	2060
	14.65	5400	160.9	2070	2040
	15.05	5480	160.9	2060	2040
	15.45	5520	159.4	2050	2040
	15.85	5600	158.6	2040	2020
	16.25	5680	157.9	2040	2020
	16.65	5720	157.1	2030	2000
	17.05	5760	156.4	2030	1990
	17.45	5840	154.9	2020	2000
	17.85	5880	154.9	2010	1980
	18.25	5920	154.9	2000	1970
	18.65	5960	152.6	1990	1970
	19.05	6000	152.6	1980	1940
	19.45	6040	152.6	1970	1950
	19.96	6120	151.1	1970	1950
	20.36	6160	151.1	1950	1950
	20.76	6200	150.4	1950	1950
	21.16	6200	149.6	1940	1950
	21.56	6280	149.6	1940	1940
	21.96	6320	148.9	1920	1940
	22.36	6360	146.6	1930	1940
	22.76	6520	142.9	1020	1990
your still hitting a good boost at 6k where mine drops to 1240 at the same rpm thats a big difference, but mines also been set up by a donut i.e me :whistle:
Ive never really had the boost 'set up' just had the correct cooling mods etc to be able to run HB9. All ive done is play with th WG and added some timing. but obviously while monitoring to logs.
