ben652
81
hartlepool
this a vag com scan of my seat leon 18 20 vavle turbo cupra on a 51 reg i have do the n75 bypass if that helps
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT 01 0002
Coding: 11510
Shop #: WSC 78905
SEZ7Z0A1233852
6 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Note: Excessive Comm Errors
Address 17 -------------------------------------------------------
Controller: 1M0 920 902 C
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05424
Shop #: WSC 69014
VSSZZZ1MZ2R015109 SEZ7Z0A1233852
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 3M Komfortgerát HLO 003
Coding: 00258
Shop #: WSC 06441
1 Fault Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 C
as u cn see i not afull scan as my battery was runng low on the laptop
