would the dump valve cause it to have a blip when idling ? i have checked the hoses around the n75 and the dumpvalve . hmmmmmmm will check dv in morning
The logs posted are no help to us.
You need to log in 4th gear, from about 2500 to the limiter, wide open throttle.
Log the following blocks in pairs
003 and 020
115 and 031
118 and 032.
I just lent my cable to Hewey on here but will have it back next weekend. Feel free to come over for some more logging (in 4th gear and in those pairs) next weekend though.
I'll drop you a text when I have the cable back.
a faulty d.v can cause many problems but in you case atleast if its checked you can put it behind you as it not being the culprit if its ok.my opinion its worth a check. im not tooo sure if you.ve serviced it if its a forge 007?
also check round the intercooler and see if there are any leaks. syptoms on idle seem similar to mine when i had a problem in the past. i sealed up a hose under the inlet manifold and cleaned and reset the throttlebody which did help it if i remember correctly. i also found air coming out of the front face on my intercooler which was leaking boost. basically a thorough boost leak check all over might reveal something.. again get the logs and it will help to see what may be causing the problem.
gulzar.
cheers andy , going to have another poke round the boost hoses and see if i can see anything .
i am still using a standard dumpvalve so worth a check.
update removed and checked the standard dumpvalve , and thats fine aswell , getting some logs tommorow on vag com so will load them up for everyone to look at thanks
003 and 020
115 and 031
118 and 032.
Redline 4th? On a private track presumably? ;)
did the runs today . on a private track;) thanks again to andy . and hopefully somebody can help out with the scan results when there uploaded . car was hitting 110 mph ish in 4th . lucky it didnt need to be done in 5th would of ended up in the tyres or crash barriers:lol:
We logged the codes today as advised earlier in this thread. All runs were done with the accelerator floored in 4th gear. A bit confused on the logging of Group 020 as it was for the idle stabilisation, but did it anyhow. Some of the formatting is a bit off line on the titles for the columns - sorry for that. There were no engine codes logged before or after testing.
If anyone can help Glen out here it would be massively appreciated.
I did find it strange that the Lambda readings in Group 32 did not change across 4 runs. The problem did hit at about 4000rpm and at 6000rpm went away on most runs. It felt as if the car was holding back rather than missing as it wasn't jerking and juddering. Between us we now very little, but began to think it was a fueling issue as a result.
Group 118 vs 032
Code:
Group A:	118				Group B:	032
	RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda	Bin. Bits	Bin. Bits
TIME					TIME
STAMP	 /min	°C	 %	 mbar	STAMP	 %	 %
0.25	2480	32	95.3	1230	0.56	0.2	0
0.86	2640	31	69.8	1570	1.16	0.2	0
1.46	2800	30	63.5	1810	1.76	0.2	0
2.07	2960	29	62	1770	2.37	0.2	0
2.67	3120	29	62	1740	2.97	0.2	0
3.28	3320	28	62	1740	3.57	0.2	0
3.88	3480	27	62	1740	4.18	0.2	0
4.48	3640	27	62.7	1750	4.78	0.2	0
5.09	3800	28	62.7	1760	5.39	0.2	0
5.69	3960	28	62.7	1780	5.99	0.2	0
6.29	4120	29	62.7	1760	6.59	0.2	0
6.9	4240	29	63.1	1760	7.2	0.2	0
7.5	4360	29	63.9	1780	7.8	0.2	0
8.1	4440	30	63.9	1770	8.4	0.2	0
8.71	4560	30	63.9	1780	9.01	0.2	0
9.31	4640	31	64.7	1790	9.61	0.2	0
9.91	4760	32	64.3	1800	10.21	0.2	0
10.52	4880	32	64.7	1790	10.82	0.2	0
11.12	5000	33	64.7	1780	11.42	0.2	0
11.72	5120	33	65.5	1800	12.03	0.2	0
12.33	5240	34	66.3	1810	12.63	0.2	0
12.93	5360	35	66.7	1810	13.23	0.2	0
13.53	5480	36	67.1	1850	13.83	0.2	0
14.14	5560	36	67.5	1820	14.44	0.2	0
14.74	5680	37	67.8	1830	15.04	0.2	0
15.34	5760	37	67.8	1840	15.65	0.2	0
15.95	5840	38	68.2	1820	16.25	0.2	0
16.55	5920	39	66.7	1810	16.85	0.2	0
17.15	6000	39	64.7	1820	17.46	0.2	0
17.77	6080	39	63.5	1740	18.06	0.2	0
18.36	6200	40	63.5	1730	18.66	0.2	0
18.96	6320	41	62.4	1780	19.27	0.2	0
19.57	6280	42	0	1640	19.87	0.2	0
Group 115 vs 031
Code:
Group A:	115				Group B:	031
	RPM	Load	Absolute Pres.	Absolute Pres.		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits
TIME					TIME
STAMP	 /min	 %	 mbar	 mbar	STAMP
0.3	2840	30.1	1840	1000	0.01	1.01	1
0.9	2920	103.8	1710	1270	0.6	0.89	1
1.51	3040	139.8	1720	1720	1.2	1.03	0.95
2.11	3240	142.1	1730	1710	1.81	1.04	0.95
2.71	3440	143.6	1750	1740	2.41	1.04	0.95
3.32	3600	143.6	1760	1750	3.01	1.03	0.95
3.92	3800	145.1	1750	1760	3.62	1.06	0.95
4.52	3960	145.9	1760	1770	4.22	1.06	0.95
5.13	4120	143.6	1770	1780	4.82	1.09	0.95
5.73	4280	145.1	1790	1760	5.43	1.09	0.95
6.43	4480	146.6	1790	1790	6.03	1.12	0.95
7.04	4640	145.9	1800	1760	6.73	1.12	0.95
7.64	4760	146.6	1800	1820	7.34	1.12	0.95
8.24	4920	145.1	1800	1790	7.94	1.16	0.95
8.85	5080	145.1	1810	1810	8.54	1.16	0.95
9.45	5200	147.4	1820	1820	9.15	1.15	0.95
10.06	5320	151.1	1830	1820	9.75	1.16	0.95
10.66	5440	152.6	1840	1820	10.36	1.16	0.95
11.26	5560	153.4	1840	1830	10.96	1.18	0.95
11.87	5640	153.4	1840	1840	11.56	1.2	0.95
12.47	5760	126.3	1820	1580	12.17	1.19	0.95
13.07	5840	153.4	1830	1910	12.77	1.25	0.96
13.67	5920	154.1	1780	1880	13.37	1.22	0.95
14.28	6000	144.4	1760	1810	13.98	1.21	0.95
14.88	6080	148.1	1760	1760	14.58	1.18	0.95
15.5	6200	148.9	1760	1700	15.18	1.13	0.93
16.1	6280	141.4	1750	1790	15.79	1.1	0.89
16.7	6360	136.1	1670	1710	16.4	1.09	0.88
Group 003 vs 020
Code:
Group A:	003				Group B:	020
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW
0.3	2680	50.31	92.9	24	0	0	0	0	0
0.91	2800	74.08	98	17.3	0.6	0	0	0	0
1.51	2960	86.42	99.6	11.3	1.21	0	0	0	0
2.11	3120	85.58	100	9.8	1.81	0	0	0	0
2.72	3280	90.14	100	15.8	2.41	0	0	0	0
3.32	3480	97.19	100	16.5	3.02	0	0	0	0
3.92	3640	102.5	100	17.3	3.62	0	0	0	0
4.53	3800	107.08	100	18	4.22	0	0	0	0
5.13	3960	112.56	99.6	18	4.83	0	0	0	0
5.73	4120	115.08	100	18.8	5.43	0	0	0	0
6.34	4240	118.58	100	18.8	6.03	0	0	0	0
6.94	4320	122.94	100	18.8	6.64	0	0	0	0
7.54	4440	125.92	100	13.5	7.24	0	0	0	0
8.15	4480	124.64	100	19.5	7.84	0	0	0	0
8.75	4600	128.39	100	18.8	8.45	0	0	0	0
9.35	4720	134.08	100	13.5	9.05	0	0	0	0
9.96	4800	133.94	100	17.3	9.66	0	0	0	0
10.56	4920	139.03	100	18	10.26	0	0	0	0
11.16	5040	143.69	100	17.3	10.86	0	0	0	0
11.77	5200	145.25	100	14.3	11.47	0	0	0	0
12.37	5280	151.86	100	18	12.07	0	0	0	0
12.97	5400	158.89	99.6	13.5	12.67	0	0	0	0
13.58	5480	160.56	99.6	15.8	13.28	0	0	0	0
14.18	5560	164.11	100	17.3	13.88	0	0	0	0
14.79	5680	164.36	100	15.8	14.48	0	0	0	0
15.39	5760	167.44	100	15.8	15.09	0	0	0	0
15.99	5840	167.72	99.6	15.8	15.69	0	0	0	0
16.59	5920	167.44	99.6	16.5	16.3	0	0	0	0
thanks again andy for today . also once we had finished the runs we sat idleing and the missfire counter found 10 + missfires in about 1 minute.
what throws me of the sent here is no fault codes?????????????????????????????
not impossible i know...
if i was you i would contact bill @ badger5 tunning he is in the tunning section,and tell him your prob, he will be able to throw some light on the matter.. infact do it now!!!!! free friendly advice
cheers
as dave says, very lean...
either real or an exhaust leak which is fooling the lambda into seeing other oxygen in there.
airflows are somewhere handy, maybe slightly down...
possibly worth disconnecting maf electrically, and re-running and see what afr it tries to achieve then.
does it have any exhaust leaks before the cat?
thanks guys will check the exhaust for any blowing .if not could it be a lambda probe ? and if so are there 2 lambdas or just the one if 2 which one do i replace front / back . lambda would definately give a missfire right ? surely though that would log an error code
I would disconnect maf and relog afr as I said earlier..
its not requesting the boost which is not a lambda reading issue but a "not asking for it" issue.. for some reason.
bill i will try and get it scanned again . with the maf unplugged . have tried driving it with it unplugged and there is no difference . to how the car performs .
just trying to get my head round this so i can understand it better myself . so log 115 is requested boost against actuall boost .
would you say my car has several problems or is the missfire at idle and running issues the same thing ?
i know its hard to say without seeing the car. just really want to get it sorted
oh and thanks for all your advice so far
