scan results
LCRglen
86
colchester essex
in case any body has not read any of my threads on my car its a 03 lcr with a missfiring problem / juddering . big thanks to andy for scanning my car .
what i need to get is can someone who knows what there looking at see anything wrong with the scans etc.
jamiebennett81
post the data in from excel using the following tags
[ code ]data[ /code ] (without the gaps)
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Didn't know what else to log so if there are any suggestions we can do some more runs to get to the bottom of it.
The car has covered 90k with FSH. The misfire kicks in at around 4k rpm and is pretty severe - I thought he was "pumping" the accelerator it was that bad.
It has paper filter, recent MAF, 2 coils packs from 4 changed and then coil packs swapped about to reseat etc
Firstly, the car siting on idle did not touch the accelerator at all. It was a little erratic in that it moved between 800 and 720
Code:
Group A:	099			Group B:	014
	RPM	Temperature	Lambda		RPM	Load	Count
TIME				TIME
STAMP	 /min	°C	 %	STAMP	 /min	 %
0.01	720	98	0	0.5	760	23.3	2
1.51	760	98	1.6	2.01	760	23.3	2
3.02	720	97	0	3.52	720	21.8	2
4.52	720	97	-3.9	5.03	760	23.3	2
6.03	720	96	-5.5	6.54	720	22.6	2
7.54	720	96	-4.7	8.04	720	23.3	2
9.05	720	96	-3.1	9.55	720	22.6	3
10.56	720	96	1.6	11.06	720	21.8	3
12.07	720	96	-0.8	12.57	720	24.1	3
13.58	720	96	0.8	14.08	760	20.3	3
15.08	720	96	0	15.59	720	23.3	3
16.6	720	96	-2.3	17.1	760	21.8	3
18.11	760	97	-3.9	18.6	760	23.3	3
19.61	760	97	-3.1	20.11	760	22.6	0
21.12	760	97	-3.1	21.62	720	21.8	1
22.63	720	97	0	23.14	720	23.3	2
24.14	720	98	0.8	24.64	720	21.1	2
25.64	760	97	0.8	26.15	720	22.6	2
27.16	720	98	2.3	27.66	720	22.6	2
28.66	760	98	-1.6	29.17	760	22.6	2
30.17	760	98	-2.3	30.67	720	21.8	2
31.68	720	98	-1.6	32.19	760	23.3	2
33.19	720	98	-3.1	33.69	720	23.3	2
34.7	720	98	0.8	35.2	760	21.8	2
36.2	720	98	0.8	36.71	800	21.1	3
37.71	720	99	3.1	38.22	720	23.3	3
39.22	720	99	1.6	39.73	760	23.3	3
40.74	720	99	-3.1	41.23	720	22.6	3
42.24	760	99	-3.1	42.74	720	22.6	3
43.75	760	99	-1.6	44.25	720	21.8	3
45.26	760	99	-0.8	45.76	720	23.3	3
46.77	760	99	2.3	47.27	720	21.8	3
48.27	720	99	0.8	48.78	720	21.1	3
49.78	760	99	1.6	50.29	720	22.6	3
51.3	720	99	2.3	51.79	760	22.6	3
52.8	720	99	-0.8	53.3	720	22.6	3
54.31	760	99	-1.6	54.81	720	22.6	3
55.82	760	99	-1.6	56.32	720	22.6	3
Another one on idle with different measuring block on Group B :-
Code:
Group A:	099			Group B:	055
	RPM	Temperature	Lambda		RPM	Lambda	Lambda	Bin. Bits
TIME				TIME
STAMP	 /min	°C	 %	STAMP	 /min	 %	 %
0.01	720	96	-2.3	0.5	760	-0.6	-1.6	10000
1	760	96	1.6	1.5	750	-0.8	-1.6	10000
2.01	720	96	1.6	2.51	770	-0.8	-1.6	10000
3.01	720	96	-3.9	3.52	750	-0.8	-1.6	10000
4.02	760	96	-4.7	4.52	760	-0.8	-1.6	10000
5.02	760	96	-3.1	5.53	770	-1.2	-1.6	10000
6.03	720	96	-5.5	6.53	740	-1.2	-1.6	10000
7.04	720	96	-6.3	7.54	730	-0.8	-1.6	10000
8.04	760	96	1.6	8.54	760	-1.2	-1.6	10000
9.05	760	96	10.9	9.55	760	-0.8	-1.6	10000
10.06	760	96	6.3	10.56	750	-1	-1.6	10000
11.06	720	96	-1.6	11.57	750	-0.6	-1.6	10000
12.07	720	96	-2.3	12.57	760	-0.6	-1.6	10000
13.07	720	96	1.6	13.57	760	-0.6	-1.6	10000
14.08	720	96	1.6	14.58	750	-0.8	-1.6	10000
15.08	760	96	-3.1	15.58	740	-0.6	-1.6	10000
16.09	720	96	-3.1	16.59	760	-0.6	-1.6	10000
17.09	720	97	1.6	17.6	760	-0.6	-1.6	10000
18.11	760	97	1.6	18.6	750	-0.8	-1.6	10000
19.11	720	97	-3.1	19.61	760	-0.6	-1.6	10000
20.11	760	97	-3.9	20.61	750	-0.8	-1.6	10000
21.12	720	97	-0.8	21.62	770	-0.8	-1.6	10000
22.13	720	97	-1.6	22.63	760	-0.8	-1.6	10000
23.13	760	97	-8.6	23.63	760	-1.2	-1.6	10000
24.13	720	98	-10.2	24.64	760	-1	-1.6	10000
25.14	720	97	-0.8	25.65	780	-1	-1.6	10000
26.15	720	97	6.3	26.65	770	-1.4	-1.6	10000
27.15	760	98	0	27.65	770	-0.8	-1.6	10000
28.16	760	98	0.8	28.66	740	-1.2	-1.6	10000
29.16	720	98	3.1	29.67	750	-1	-1.6	10000
30.17	720	98	2.3	30.67	760	-0.8	-1.6	10000
31.17	720	98	-2.3	31.68	750	-0.6	-1.6	10000
32.18	760	98	-3.1	32.68	760	-0.6	-1.6	10000
33.18	720	98	0.8	33.69	760	-0.6	-1.6	10000
34.19	760	98	1.6	34.69	730	-0.8	-1.6	10000
35.2	760	98	-3.1	35.7	740	-0.8	-1.6	10000
36.2	720	98	-3.1	36.71	760	-0.6	-1.6	10000
37.21	720	99	1.6	37.71	750	-0.8	-1.6	10000
38.21	720	98	0	38.72	740	-0.8	-1.6	10000
39.22	760	98	-5.5	39.72	750	-0.8	-1.6	10000
40.23	760	99	-6.3	40.73	760	-1	-1.6	10000
41.23	720	99	-4.7	41.73	760	-1.2	-1.6	10000
42.24	720	99	-5.5	42.74	710	-0.8	-1.6	10000
43.24	760	99	-3.1	43.75	750	-1	-1.6	10000
44.25	760	99	3.9	44.75	800	-1.6	-1.6	10000
45.25	720	99	4.7	45.76	770	-1.2	-1.6	10000
46.26	720	99	4.7	46.76	740	-1.2	-1.6	10000
47.27	720	99	-2.3	47.77	740	-0.8	-1.6	10000
48.27	720	99	-2.3	48.77	770	-0.8	-1.6	10000
49.28	720	99	0.8	49.78	760	-0.8	-1.6	10000
50.28	720	99	0.8	50.8	750	-0.8	-1.6	10000
51.29	760	99	-3.1	51.79	740	-0.6	-1.6	10000
52.29	760	99	-3.1	52.8	770	-0.6	-1.6	10000
53.3	720	99	1.6	53.8	760	-0.6	-1.6	10000
54.31	720	99	1.6	54.81	760	-0.8	-1.6	10000
55.31	760	99	-3.1	55.82	750	-0.8	-1.6	10000
56.32	720	99	-3.9	56.82	760	-0.8	-1.6	10000
...and again, idling with a blip of the throttle and the MAF and Timing listed in Group C :-
Code:
Group A:	001				Group B:	014				Group C:	003
	RPM	Temperature	Lambda	Bin. Bits		RPM	Load	Count	CODES Not Loaded		RPM	Mass Flow	Load	Ign. Timing
TIME					TIME					TIME
STAMP	 /min	°C	 %		STAMP	 /min	 %			STAMP	 /min	 g/s	 %	 °ATDC
0.99	1440	98	0	11100011	0.01	1320	29.3	0	TXT 000 103	0.5	1360	22.64	25.1	14.3
2.51	1800	99	3.1	11101011	1.5	1560	78.2	0	TXT 000 104	2.01	1680	28.56	76.5	11.3
4.02	2200	98	10.9	11101001	3.02	1920	90.2	0	TXT 000 104	3.51	2040	41.06	87.1	12
5.52	2800	98	21.9	11101001	4.52	2400	117.3	0	TXT 000 103	5.03	2600	71.39	95.7	10.5
7.04	3160	98	0	11100001	6.03	2880	160.9	0	TXT 000 103	6.54	3040	91.56	100	5.3
8.55	3600	98	21.1	11101001	7.54	3280	147.4	1	TXT 000 103	8.04	3400	95.14	100	14.3
10.05	4160	97	21.1	11101001	9.05	3800	147.4	1	TXT 000 103	9.55	4000	113.08	100	16.5
11.56	4640	96	21.9	11101001	10.56	4360	146.6	1	TXT 000 103	11.06	4480	125.19	100	15.8
13.07	4600	96	0	11110001	12.07	4760	90.2	1	TXT 000 103	12.57	4760	6.97	7.1	4.5
14.57	3880	96	0	11110001	13.58	4360	12	1	TXT 000 104	14.08	4120	9.72	7.8	4.5
16.09	3400	96	0	11110001	15.08	3640	12.8	1	TXT 000 104	15.59	3480	8.92	7.1	2.3
17.6	3160	96	0	11110001	16.59	3320	13.5	1	TXT 000 104	17.09	3240	8.69	7.1	2.3
19.11	2960	95	0	11110001	18.1	3120	13.5	1	TXT 000 104	18.59	3040	7.92	6.7	2.3
20.61	2800	95	0	11110001	19.61	2920	13.5	1	TXT 000 104	20.11	2880	7.33	6.3	1.5
22.12	2760	95	-0.8	11100001	21.11	2760	13.5	1	TXT 000 104	21.61	2680	7.14	5.9	0.8
23.63	3080	93	0	11100001	22.63	2880	107.5	1	TXT 000 104	23.13	3040	80.36	86.7	19.5
25.14	2840	93	0	11110001	24.14	3080	15.8	2	TXT 000 104	24.64	3000	7.86	6.7	3
26.65	2640	93	0	11100001	25.63	2720	12.8	2	TXT 000 104	26.15	2600	6.33	5.5	0.8
28.16	2680	93	-3.1	11101001	27.14	2600	20.3	2	TXT 000 104	27.66	2640	20.14	12.9	18
29.67	2800	92	-5.5	11101001	28.65	2760	29.3	2	TXT 000 103	29.16	2800	7.67	6.3	9.8
31.18	2920	92	-5.5	11111001	30.17	2840	42.1	2	TXT 000 104	30.67	2880	7.75	6.7	27.8
32.68	2880	91	0	11110001	31.67	2920	14.3	2	TXT 000 104	32.18	2920	7.44	6.3	1.5
34.19	2760	90	0	11110001	33.19	2760	13.5	2	TXT 000 104	33.69	2760	7.08	5.9	1.5
35.7	2640	90	0	11110001	34.69	2760	12.8	2	TXT 000 104	35.2	2720	7.22	5.9	0.8
37.21	2400	90	0	11110001	36.19	2600	13.5	2	TXT 000 104	36.7	2520	6.69	5.5	0.8
38.72	2240	90	0	11110001	37.71	2360	13.5	2	TXT 000 104	38.21	2280	6	5.1	-1.5
40.23	1960	90	0	11110111	39.21	2160	13.5	2	TXT 000 104	39.72	2040	5.36	4.7	-3.8
41.74	1960	90	-0.8	11101011	40.73	1960	15	2	TXT 000 104	41.23	1960	5.22	4.7	-5.3
43.25	2240	89	6.3	11101001	42.24	1960	32.3	2	TXT 000 104	42.74	2080	34.81	87.5	16.5
44.75	2840	89	21.9	11101001	43.75	2400	107.5	2	TXT 000 103	44.25	2600	69	95.7	13.5
46.26	3160	88	0	11100001	45.25	2920	163.9	0	TXT 000 103	45.75	3040	86.36	100	4.5
47.77	3600	88	0	11100001	46.76	3360	140.6	1	TXT 000 103	47.27	3440	113.69	100	8.3
49.28	3920	88	0	11100001	48.27	3760	122.6	1	TXT 000 103	48.78	3840	123.06	100	12.8
50.79	4240	88	21.9	11101001	49.78	4040	118	1	TXT 000 103	50.29	4200	121.72	98.8	21.8
52.3	4800	88	18.8	11101001	51.29	4440	153.4	1	TXT 000 103	51.79	4640	132.19	100	16.5
53.81	5120	88	19.5	11110001	52.8	4960	126.3	1	TXT 000 104	53.3	5120	120.44	100	18.8
55.31	4720	88	0	11110001	54.31	5080	14.3	1	TXT 000 104	54.81	4880	9.56	8.2	5.3
56.82	4200	88	0	11110001	55.82	4560	12	1	TXT 000 104	56.32	4360	10.36	8.2	3.8
58.33	3880	88	0	11110001	57.32	4080	12	1	TXT 000 104	57.83	3920	9.94	7.5	3
59.84	3760	88	0	11110001	58.82	3840	12	1	TXT 000 104	59.34	3800	9.61	7.5	3.8
61.35	3600	87	0	11110001	60.34	3720	12.8	1	TXT 000 104	60.83	3680	9.11	7.1	3.8
62.86	3480	87	0	11110001	61.84	3560	12	1	TXT 000 104	62.35	3520	8.92	7.1	3
64.37	2680	87	0	11110001	63.35	3480	13.5	1	TXT 000 104	63.86	3080	8.47	7.1	2.3
65.87	2640	87	0.8	11101001	64.87	2680	13.5	1	TXT 000 104	65.37	2640	8.17	6.7	0
67.38	2680	87	0	11100001	66.38	2640	39.1	1	TXT 000 104	66.88	2640	28.22	16.1	18
68.89	2800	87	-3.1	11101001	67.89	2720	65.4	1	TXT 000 104	68.39	2760	26.06	14.9	29.3
70.4	2800	87	0.8	11101001	69.39	2800	41.4	1	TXT 000 103	69.9	2800	19.08	12.2	33
71.91	2840	87	0.8	11101001	70.9	2800	42.1	1	TXT 000 103	71.41	2840	27	15.7	30.8
73.42	2920	86	0	11100001	72.41	2880	48.1	1	TXT 000 103	72.91	2880	31.08	16.9	30
74.93	3000	86	-3.1	11101001	73.92	2960	67.7	1	TXT 000 103	74.42	3000	23.42	14.1	32.3
76.43	3200	86	18.8	11101001	75.43	3040	91	1	TXT 000 103	75.93	3120	86.06	95.7	18.8
77.94	3000	86	0	11110001	76.94	3280	111.3	1	TXT 000 103	77.44	3400	30.78	34.1	25.5
79.45	2800	86	9.4	11101001	78.45	2720	60.2	0	TXT 000 103	78.95	2760	51.17	28.2	24.8
80.96	2880	86	0	11100001	79.95	2840	107.5	0	TXT 000 104	80.46	2880	25.67	15.7	28.5
82.47	3040	86	21.1	11101001	81.46	2920	83.5	0	TXT 000 103	81.97	2960	77.47	98.8	20.3
83.98	2920	86	0	11110001	82.97	3000	13.5	0	TXT 000 104	83.47	2960	5.83	6.3	10.5
85.49	2800	86	0	11110001	84.48	2880	12.8	0	TXT 000 104	84.97	2840	7.22	5.9	1.5
86.99	2680	86	0	11110001	85.98	2760	13.5	0	TXT 000 104	86.49	2720	7.08	5.9	0.8
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Then on a run, accelerating in 3rd gear only :-
Code:
Group A:	001				Group B:	014				Group C:	115
	RPM	Temperature	Lambda	Bin. Bits		RPM	Load	Count	CODES Not Loaded		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME					TIME
STAMP	 /min	°C	 %		STAMP	 /min	 %			STAMP	 /min	 %	 mbar	 mbar
0	1360	86	1.6	11101011	0.5	1480	83.5	0	TXT 000 104	1.01	1640	88.7	1660	1190
1.52	1760	87	2.3	11101011	2.02	1920	94.7	0	TXT 000 103	2.52	2080	101.5	1750	1360
3.02	2280	87	11.7	11101001	3.53	2480	130.1	0	TXT 000 103	4.03	2640	147.4	1890	1860
4.53	2840	87	24.2	11101001	5.04	3040	168.4	0	TXT 000 103	5.54	3240	157.1	1910	1900
6.04	3480	87	21.9	11101001	6.55	3680	160.2	0	TXT 000 103	7.05	3880	160.2	1950	1950
7.55	4080	87	21.9	11101001	8.06	4240	160.2	0	TXT 000 103	8.56	4400	161.7	1930	1940
9.06	4600	87	21.9	11111001	9.56	4560	12.8	0	TXT 000 104	10.07	4400	14.3	1000	1110
10.57	4200	88	0	11110001	11.07	3920	12	0	TXT 000 104	11.57	3600	12	1000	1050
12.08	3400	88	0	11110001	12.58	3200	13.5	0	TXT 000 104	13.08	3040	13.5	1000	1040
13.58	2840	88	0	11110001	14.08	2720	13.5	0	TXT 000 104	14.59	2600	13.5	1000	1030
15.1	2520	88	0	11110001	15.6	2440	13.5	0	TXT 000 104	16.09	2360	13.5	1000	1030
16.6	2360	88	0	11100001	17.11	2400	51.9	0	TXT 000 104	17.6	2440	15.8	1000	1080
18.11	2360	88	0	11110101	18.61	2320	12.8	0	TXT 000 104	19.11	2160	12.8	1000	1030
19.62	1920	88	0	11110111	20.11	1720	12	0	TXT 000 104	20.62	1520	12.8	1000	1020
21.12	1280	88	0	11110111	21.62	1000	16.5	0	TXT 000 104	22.13	840	18.8	1000	1010
22.63	760	88	0	11110111	23.13	720	19.5	0	TXT 000 104	23.63	760	21.8	1000	1010
70.9	1160	92	3.1	11101011	71.41	1280	78.2	0	TXT 000 104	70.4	1080	70.7	1380	1070
72.42	1560	92	1.6	11101011	72.91	1680	88.7	0	TXT 000 104	71.91	1400	80.5	1550	1140
73.92	2000	93	6.3	11101001	74.43	2160	107.5	0	TXT 000 103	73.43	1840	91	1710	1240
75.44	2560	93	21.1	11101001	75.94	2800	148.9	0	TXT 000 103	74.94	2360	118.8	1790	1520
76.95	3240	93	21.9	11101001	77.45	3480	143.6	0	TXT 000 103	76.45	3040	154.9	1760	1890
78.46	3920	93	21.1	11101001	78.96	4120	146.6	0	TXT 000 103	77.95	3720	146.6	1780	1790
79.96	4520	93	21.1	11101001	80.47	4680	147.4	0	TXT 000 103	79.46	4320	144.4	1810	1800
81.47	5080	93	22.7	11101001	81.98	5240	152.6	0	TXT 000 103	80.97	4880	147.4	1830	1790
82.98	5600	93	22.7	11101001	83.49	5520	12.8	0	TXT 000 104	82.48	5400	151.1	1850	1850
84.49	4280	93	0	11110001	84.99	4240	12	0	TXT 000 104	83.99	4200	15.8	1000	1160
85.99	4040	93	0	11110001	86.5	3960	12	0	TXT 000 104	85.5	4160	12	1000	1060
87.51	3760	93	0	11110001	88	3680	12.8	0	TXT 000 104	87	3840	12	1000	1050
89.01	3560	93	0	11110001	89.52	3520	12	0	TXT 000 104	88.5	3600	12	1000	1050
90.53	3440	93	0	11110001	91.02	3400	13.5	0	TXT 000 104	90.01	3480	13.5	1000	1040
92.03	3360	93	0	11110001	92.54	3400	74.4	0	TXT 000 104	91.52	3400	12.8	1000	1040
93.54	3560	93	9.4	11100001	94.05	3600	156.4	0	TXT 000 103	93.04	3440	97	1430	1350
95.05	3800	92	0	11100001	95.55	3880	119.5	1	TXT 000 103	94.55	3720	157.1	1740	1900
96.56	4080	92	0	11100001	97.06	4160	84.2	1	TXT 000 103	96.06	4000	120.3	1770	1560
98.07	4000	91	0	11110001	98.57	3880	12	1	TXT 000 104	97.57	4120	13.5	1000	1200
99.57	3600	91	0	11110001	100.07	3520	12.8	1	TXT 000 104	99.07	3760	12	1000	1060
101.09	3440	90	0	11100001	101.59	3520	100.8	1	TXT 000 104	100.58	3440	12.8	1010	1050
102.59	3720	90	21.9	11101001	103.1	3880	153.4	1	TXT 000 103	102.09	3640	144.4	1800	1790
104.1	3720	90	0	11110001	104.61	3560	11.3	1	TXT 000 104	103.6	3840	12.8	1010	1320
105.6	3160	90	0	11110001	106.11	3000	12.8	1	TXT 000 104	105.1	3360	12.8	1010	1060
107.12	3000	90	-0.8	11100001	107.62	3040	30.1	1	TXT 000 104	106.62	2960	13.5	1010	1030
108.63	3040	90	0	11110001	109.13	3000	12	1	TXT 000 104	108.13	3080	15.8	1010	1120
110.13	3000	89	0	11110001	110.64	2960	12.8	1	TXT 000 104	109.62	3000	12.8	1010	1040
111.65	2920	89	0	11110001	112.14	2880	13.5	1	TXT 000 104	111.14	2920	13.5	1010	1030
.......and again - different measuring blocks
Code:
TIME					TIME					TIME
0.99	1120	93	0	11100011	0	1560	16.5	0	TXT 000 103	0.49	1400	13.42	11	27
2.5	1360	93	5.5	11110111	1.5	1200	71.4	0	TXT 000 104	2.01	1320	14.97	15.3	17.3
4.01	1520	94	0	11100011	3.01	1400	32.3	0	TXT 000 103	3.52	1440	22.28	25.5	12
5.53	1920	94	7	11101011	4.51	1640	78.2	0	TXT 000 103	5.03	1800	29.86	80.8	12.8
7.04	2400	95	14.8	11101001	6.02	2080	91	0	TXT 000 103	6.54	2240	46.06	90.2	12.8
8.55	3040	95	23.4	11101001	7.54	2600	122.6	0	TXT 000 103	8.04	2800	78.33	98	12
10.06	3600	95	21.9	11101001	9.04	3200	162.4	0	TXT 000 103	9.55	3400	93.69	100	11.3
11.56	4200	95	21.1	11101001	10.56	3840	148.9	0	TXT 000 103	11.06	4000	112.5	100	14.3
13.07	4520	95	7	11110001	12.07	4360	145.9	0	TXT 000 103	12.57	4560	128.25	100	16.5
14.58	3760	95	0	11110001	13.58	4360	14.3	0	TXT 000 104	14.08	4040	8.03	7.1	4.5
16.09	3040	96	0	11110001	15.08	3480	12.8	0	TXT 000 104	15.59	3240	8.5	7.1	2.3
17.59	2680	95	0	11110001	16.59	2880	12.8	0	TXT 000 104	17.1	2760	7.11	6.3	1.5
19.11	2560	95	0	11110001	18.1	2640	13.5	0	TXT 000 104	18.61	2600	6.83	5.9	0.8
20.62	2400	95	0	11110001	19.6	2520	13.5	0	TXT 000 104	20.11	2440	6.44	5.5	0
22.12	2360	95	5.5	11101001	21.11	2360	13.5	0	TXT 000 104	21.62	2360	10.83	8.6	20.3
23.63	2440	95	3.9	11101001	22.63	2400	30.8	0	TXT 000 104	23.13	2400	15	10.6	29.3
25.14	2520	95	0.8	11101001	24.13	2480	27.8	0	TXT 000 103	24.64	2480	13.36	10.2	32.3
26.65	2520	95	3.9	11101001	25.65	2520	21.1	0	TXT 000 103	26.15	2520	8.72	7.5	35.3
28.16	2680	95	2.3	11101001	27.15	2560	38.3	0	TXT 000 103	27.66	2640	28.58	16.9	29.3
29.67	2800	95	4.7	11101001	28.66	2720	34.6	0	TXT 000 103	29.16	2760	24.39	15.3	30.8
31.18	3280	94	0	11100001	30.17	2960	94	0	TXT 000 103	30.67	3120	85.75	100	13.5
32.69	3440	94	1.6	11110001	31.68	3360	156.4	0	TXT 000 103	32.18	3440	5.14	5.1	33
34.18	3080	94	0	11110001	33.18	3320	12	0	TXT 000 104	33.68	3200	7.69	6.7	2.3
35.7	2840	94	0	11110001	34.7	3000	12.8	0	TXT 000 104	35.2	2920	7.22	6.3	1.5
37.21	2640	94	0	11110001	36.2	2800	12.8	0	TXT 000 104	36.71	2720	7.19	5.9	0.8
38.71	2480	94	0	11110001	37.71	2600	12.8	0	TXT 000 104	38.22	2520	6.53	5.5	0.8
And finally..............
Code:
Group A:	001				Group B:	014				Group C:	002
	RPM	Temperature	Lambda	Bin. Bits		RPM	Load	Count	CODES Not Loaded		RPM	Load	Inj. On Time	Mass Flow
TIME					TIME					TIME
STAMP	 /min	°C	 %		STAMP	 /min	 %			STAMP	 /min	 %	 ms	 g/s
0.99	1200	89	3.9	11101011	1.49	1320	79.7	0	TXT 000 104	0.5	1080	74.4	7.82	15.58
2.51	1560	90	2.3	11101011	3.01	1720	90.2	0	TXT 000 104	2.01	1440	82	8.84	24.47
4.01	2040	90	7.8	11101001	4.52	2200	112	0	TXT 000 103	3.52	1880	94.7	10.54	35.28
5.53	2600	90	21.9	11101001	6.03	2840	150.4	0	TXT 000 103	5.02	2400	127.1	15.3	64.17
7.04	3280	90	21.1	11101001	7.54	3520	145.1	0	TXT 000 103	6.53	3080	150.4	18.36	86.56
8.54	3960	90	21.1	11101001	9.05	4160	148.1	0	TXT 000 103	8.04	3760	149.6	18.02	106.72
10.05	4600	90	21.9	11101001	10.56	4800	147.4	0	TXT 000 103	9.55	4360	148.1	17.34	125.75
11.56	5120	90	18.8	11101001	12.06	5080	13.5	0	TXT 000 104	11.06	5000	140.6	16.32	141.06
13.07	4560	91	0	11110001	13.56	4440	12	0	TXT 000 104	12.57	4880	13.5	0	9.64
14.58	4440	91	2.3	11101001	15.08	4480	94	1	TXT 000 104	14.08	4400	12	0	10.47
16.09	4560	90	0	11110001	16.59	4520	14.3	1	TXT 000 104	15.58	4600	139.1	13.6	126.19
17.6	4120	91	0	11110001	18.1	3960	12	1	TXT 000 104	17.09	4320	12	0	9.08
19.1	3760	90	0	11110001	19.61	3720	13.5	1	TXT 000 104	18.6	3840	12	0	9.06
20.61	3760	90	-1.6	11101001	21.12	3760	15.8	1	TXT 000 104	20.11	3720	68.4	7.14	58.39
22.12	3400	90	0	11110001	22.62	3040	12.8	1	TXT 000 104	21.62	3680	14.3	1.7	6.64
23.62	2440	90	0	11110001	24.12	2200	12.8	1	TXT 000 104	23.12	2720	12.8	0	6.47
25.13	1640	90	0	11110111	25.63	1360	12.8	1	TXT 000 104	24.63	1920	12.8	0	4.78
26.64	1160	90	0	11100011	27.14	1200	74.4	1	TXT 000 104	26.13	1160	14.3	1.36	4.06
28.15	1400	90	3.1	11101011	28.65	1560	84.2	1	TXT 000 104	27.65	1320	76.7	7.82	20.61
29.67	1800	90	3.9	11101011	30.16	1960	97	1	TXT 000 103	29.16	1680	89.5	9.86	30.25
31.17	2320	90	14.1	11101001	31.68	2520	134.6	1	TXT 000 103	30.67	2120	106.8	12.24	46.81
32.68	2960	90	21.9	11101001	33.17	3160	145.1	1	TXT 000 103	32.18	2720	147.4	18.02	79.42
34.19	3600	90	21.1	11101001	34.69	3840	147.4	1	TXT 000 103	33.69	3400	145.1	17.34	94.69
35.7	4160	90	0	11100001	36.2	4320	148.1	1	TXT 000 103	35.2	4040	146.6	17.68	113.08
37.21	4680	90	21.9	11101001	37.71	4840	148.9	1	TXT 000 103	36.71	4480	148.9	17.34	127.33
38.72	5160	90	21.9	11101001	39.22	5320	152.6	1	TXT 000 103	38.21	5000	147.4	17.34	143.89
40.22	5600	90	23.4	11101001	40.74	5680	154.1	1	TXT 000 103	39.72	5480	156.4	18.7	160.83
41.73	4480	90	0	11100001	42.24	4520	137.6	1	TXT 000 103	41.23	5320	12	1.36	8.75
43.24	4720	90	21.9	11101001	43.75	4800	121.8	0	TXT 000 103	42.74	4640	143.6	16.66	128.86
44.75	4600	90	0	11110001	45.25	4440	12	0	TXT 000 104	44.25	4720	12.8	1.36	6.53
46.26	4000	90	0	11110001	46.76	3760	12	0	TXT 000 104	45.76	4240	12	0	9.67
LCRglen
86
colchester essex
thanks andy . right today i changed the other 2 coil packs so all of them are new also regapped all the plugs to exactly 0.8mm .must say it is smoother BUT it still has the missfire it is definately alot better and the missfire isnt as bad hardley noticeable but still there and on tickover . hmmmmmm
LCRglen
86
colchester essex
please help seriously baffled
right where to start .:cry::cry: i have an 03 lcr with a persistant missfire or boost problem that gets worse when hot . egf if you sat at standstill for 10 mins idling and let it really heat up the problem is far worse . right so far the car has had .
new MAF( 2 monthes ago)
new coil packs ( 1 month ago)
throttle body clean ( 2 weeks ) and realignement on vag com
new hose under inlet manifold ( covered in crusty oil )
plugs (4 monthes ) took these out and yes they are gapped to .8
redex fuel inj cleaner
the car has had a scan kindley by andy on here S3 AKR
and there were no fault codes . this has been checked twice andy also took some logs which we posted in the relvent vag forum on here but got no replys .
somebody HELP ideas anything running out of money fast and actually am beginning to hate the car and considering selling it ,( dont want to but ):cry::cry::cry::cry:
i can reward people heavly with beer bacon sandwichs etc .
just need ideas have scanned these forums for weeks and now i cant take it no more :cry:
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
is it using waters?
are all the spark plugs complete?? with the ceramic part there? ive had a car with a miss fire only a small 1 but was annoying the guy that was the problem.
LCRglen
86
colchester essex
its using no water , oil is good colour and so is water , also the plugs appear to be ok all the same colour . they are the ngk ones with the small tip , there feels like a blip when its idleing aswell , its not lumpy like its running on 3 cylinders either. i will bump my vag com scan results if anyone wants to look .
gulzar
LCR jabba'd
Oct 1, 2007
178
The logs posted are no help to us.
You need to log in 4th gear, from about 2500 to the limiter, wide open throttle.
Log the following blocks in pairs
003 and 020
115 and 031
118 and 032.
agree with this matey. need to do these blocks. will help with boost actual vs requested, timing , flowrates and load on engine.
have you checked the d.v? any split hoses anywhere?
gulzar
