Hey buddy, there is a connector but no wire coming out of it. I'm going to upload a video for you. The car was damaged from (front)passenger side maybe the cable has been damaged. Thats why its not connected to the pump.
It doesnt let me post it, i need minimum 15 post to send a link.
https://vimeo.com/187461125
As you can see from the video there is a connector but no wire.
I believe this is the pump part no: 6R0423156B
Seat Ibiza 2014 1.2 Power Steering failure when parking & stationary
Thanks buddy, i thought the wire was missing. I will get the coding changed as soon as posibble. By the way do you know where i can get this done? And how much would they charge? Or I have VCDS on my laptop, where can i get the cable from? I bought one from Ebay but it didnt work.
wich version did you bought?
the 409.1 doesn't work on the Ibiza mk5, only cars until 2002
Ohh I didnt know. Which version shall I buy?
something like this:
link removed
probably cheaper if you can find someone with a cable near you.
I'm not from the UK so can't help :(
That looks like a "rip off" version, no RossTech royalties paid there I'd expect!
High risk and no help if you get into trouble!
Okay if you regularly do a bit of shoplifting.
I was reticent to put the link here, I have no idea what's official or not regarding the vcds... Is there any official version cheap?
Maybe find a garage for them to do it for you. As long as you tell them what you want to do, and they have the right tool, wich they should have it will be no problem.
PS: The cause the pump has the incorrect code is because apparently at some poing someone replaced it by a pump beloging to a car without ESP and didn't change the coding to the correct one. Very common among pumps fitted outside the dealer, almost no one knows they require coding.
I think that the problem is if you buy the legal VCDS Lite version, you are very limited to what you can use it for, ie I don't think that you can make coding changes - which is exactly what you are suggesting is needed here.
Hey buddy,
I would like to thank you for your help, i really appriciate it.
I bought the cable, managed to change the code works perfect now.
Once again, Thank you.
Hey buddy,
Nice to know, the Ibiza steering is pretty good when there are no problems... Unfornatly mine has a stiff steering and can't find the problem, that's why i know all this stuff :cry:
Ohh, makes sense now because you knew exactly whats wrong with it.
I was talking about this thread. Have a look at this and play around with the x - 112x1 (code) try different values such as 3 or 4 this may resolve your issue.
http://www.seatcupra.net/forums/showthread.php?t=381058
No, in my case it's the steering box or suspension. Alredy played with that and made no difference.
