ANDY BLUNT said:Fitted Rog's S3 upper brace today had to do a little bit of modding to get it to fit around bonnet lifter,but was only to remove about 2mm from brace.Used stainless bolts etc for rust prevention and after drilling holes hoovered up swarf and painted all bare metal with touch up kit.Looks factory ,not sure how its affected handling ,so will leave Rog to post that up. WARNING LEON R MODEL DOES NOT NEED LOWER BRACE ,IT IS FITTED AS STANDARD..Fitted Samco hoses too TIP wasn't too bad a job ,but n/s hose didn't sit right so i removed a bit of pipe off each end too get it too fit ,but i took too much off one end
,managed to sort it out though with Shock Xe 's help.We urm forgot to reconnect Maf sensor though
so Rog had a fault code,but Mike sorted it with VAGCOM .
Andy.
Hi Andy.
I don" t see that you have a bigger downpipe in your mods. If not, put immedately one.
In Greece, when with K03s, they put 70mm downpipe, and 63mm the rest.
Theodore.
Andy.
