Hi Ive just looked through this whole thing and I’m having a problem with my Harmon screen I don’t have access to the performance screen at all even tho my car is a cupra I don’t know if it’s been switched if that can cause this but would really like some help on how to get it or do I have to buy a new screen all together thanks.
Don't get a new screen. Did you try a factory reset and setting up the device again?
Or put it in developer mode, where you can choose your model manually:
Try this :
create a file:
\VwBrandDevice\Settings\UserSettingsDevMode.default with notepad
with contents:
Code:
<?xml version='1.0' encoding='iso-8859-1'?>
<Settings>
    <Active>1</Active>
</Settings>
make sure it's .default
then create a file called branddevice.reg and put it to the root /.
reboot and then you maybe able to manually chose your brand/skin. (All settings (route profiles, last targets...) will be lost)
ECO Perf Switcher
TOOL:
This is a tool to quickly switch between Performance and ECO Trip:
Extract zip, then copy the folder to the internal Storage /Apps/ .
In addition you need edited Watchdog.ini files otherwise your device will just reboot.
Download Tool
Watchdog INI Files
Hi, my Device reboot when i choose Eco/Performance. What must be change in Watchdog.ini?
Best Regards
Here is the latest version from 2015. Replace the old one, Backup first.
Hi mate i'm trying to bypass the performance mode but it keeps saying to put it in the car that it originally came from which i dont have as the garmin is second hand.
Is there any ways to bypass it now? i'm also looking into reversing the device but can't find anything with 'performance' in the usershell.
I found a method...
-Create an empty file in the root BrandDevice.reg to reset the pairing on next boot;
-Also create a file VwBrandDevice\Settings\UserSettingsDevMode.default:
<Settings>
<Active>1</Active>
<VehicleIdentificationNumber>WVWZZZAAZFZ123457</VehicleIdentificationNumber>
</Settings>
just bought a garmin but doesn’t have a performance mode as it’s on a ibiza fr 2014 but do i need SD card etc for this and can someone put a link for me to copy for it, and does it need resetting
cheers
