question: on the mark 5 cupra the 4pot sport brakes are an option, is this also the case for the mark4 cupra or are the AP racing brakes standard?
does that mean the wheels off the mk5 will fit on the mk with the ap racing brakes?
i have given up cleaning them, the more i try the more pink they turn!
More info...... OP's Retaining pins : CP6607-31 is actually a full retaining pin set + pads+retaining springs.
Correct order code just for the pins is...... CP7600-109 @ a massive £1.28 each!!!!
Wow, makes you wonder how Seat can charge £143 for the LCR Brembo pins and springs (no pads)!!
Apart from the pins being slightly longer for the LCR, the set is almost identical [:@]
Also just got a set of DS2500 for £77
Where did you get them from mate? I rang AP Racing and they said to go through one of their distributors :help:
Just done brakes all round...one awful ordeal that took the ENTIRE weekend. Writeup and pics to follow...
But for now...
Pads EBC Red Stuff:
Fronts: DP3036C £79.99 For cars with AP Calipers
Rears: DP3680C £40.07
Discs
D930 £69.08 312mm EBC Standard discs
D816 £32.86
Then AP Pins £1.84
Bleed screws £2 each
Bleed screw rubber cap 98p each
Or something like that anyway...
All in for £240 quid or so I guess. It hurts but I'd rather not have left it with SEAT, or a local garage who would have got in a mess and called me to explain! :wtf:
