SEAT Sport FMIC Diagram
air121005
1,609
Worcestershire
i have recently posted this in a thread :whistle: but thought that it might be of benifit to everybody! :D
got this diagram from my local stealer (Droitwich, Worcs), thought i'd share it to make the FMIC conversion pricing, installation process etc a lot easier! ;)
was told if i quote the illustraion No: 145-46 , then the item number, parts can be quoted for & ordered.
the actual SEAT part number for the SEAT Sport FMIC is: 6LL145804 ,
which i was quoted £262.85 + VAT :blink: (£308.85)
hope this info proves useful!
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
il post it in here too :)
has any1 replaced the ristrictive plastic tube where numbers 8 and 10 are on the diagram also there is a sensor in that part further toward the throttle body how have people gone about keeping this and it still working and in a tight seal still??? (sensor is part number 23 on diagram)
air121005
1,609
Worcestershire
air121005
1,609
Worcestershire
thought it would be an air temperature sensor, as its after the FMIC?:shrug:
i may be wrong!:shrug:
wouldn't the MAP sensor be on the inlet manifold?
again, i may be wrong!:shrug:
air121005
1,609
Worcestershire
iirc, that sensor is on item 9 on the SMIC setup.
rash, couldn't you use item 9 from the SMIC setup and replace the restrictive item 8 with ali & silicone of your choice! ;)
rashcupra
Oct 15, 2006
6,517
crawley
the map sensor does have a home on modded pipe then! :funk: il have to nag forge for the part seperate when i FINALLY get the car back :(
