odd-head
new to the dub scene
Feb 27, 2010
87
calne, wiltshire
hello everyone
my car is due its 80k service at the end of the month.
oil
oil filter
panel filter
inside filter
spark plugs
check tensioners
SEAT - £284
AUDI/VW CENTRE - £240 they claimed to be alot cheaper on my local radio. £44 is not alot cheaper. http://www.audivwcentre.com/index.php/service-bromham
are these prices good?
my postcode is SN11 0SD, near Swindon, Wiltshire anyone know any good VAG specialists???????????????????
Not sure if those are good prices for the work involved, though it seems a bit on the steep side imo. Just for reference, I recentley had a 87K service done on my V5 170 at Arnold Clark Seat in Glasgow for £69 for an oil change and all the filters. Didn't change the plugs and not sure if they would have checked the tensioners though.
Definatley sounds steep, if that's all they're doing. Can be any more than £100 in parts if you were to do it yourself. Although an 80k is a major service I think so I'd expect they'd do more than what you listed - brake fluid etc?
just found this after a good google search
Engine Oil - change
Engine Filter - change
Timing Belt - check
V-Belt - check tension/condition
Ribbed Belt - check condition
Spark Plugs - replace
Air Cleaner - replace filter
Windshield Washer Fluid - check level
Automatic Shift Lock-check operation
Brake System - check damage/leaks, pad thickness, fluid level
Wheels - rotate from front to rear
Air Bag System - check function/damage
Battery - check electrolyte level
Pollen Filter - replace
Cooling System - check level
Automatic Transmission - check for leaks
Manual Transmission - check for leaks
Tires/Spare - check condition
Driveshaft - check boots
On Board Diagnostics -check Diagnostic Trouble Code memory
Door Hinge - lube
Headlights - check and adjust if necessary
Brake Fluid
