Model Year 22/23 Servicing
Villabrand
131
59
Had the Aircon service done after two years as they advised was due. But I'm on a service plan so did not question, although did think to myself is it really necessary when I've only done 9k miles.
SRGTD
2,757
1,611
My VZN less than 2 years old, today I booked car for my 3rd service.
Very strange thing they said aircon service which I rejected. As there was price associated.
So went for only oil / oil filter 263£ and Haldex 125£
Now this is new air-conditioning service, has anyone been told this is now part of service if I don't get it done it will spill into next service?
This is pure money making tactics as far as I think.
Thanks.
I used to own a VW and VW‘s service advisors always used to try and ‘encourage‘ customers to buy the air con service, but it was never a chargeable part of the standard service. The air con service was a VW recommendation, not a requirement to maintain the car’s warranty in force so I adopted the approach that if the air con was working efficiently, I‘d decline the air con service.
Whether this has now changed I don’t know as I’m no longer a VW owner.
James_R
5,663
79
37
Manchester
Thanks.
At two years old your vehicle is due an air conditioning service and brake fluid change, it's been that way for quite some time.
R134a and R1234yf are recommended every 2 years and R744 every 4 years.
Seriously?
1,466
1,061
Is brake fluid 2 years now?
I always worked the basis of 3 years.
Delanor
132
46
My VZN is 2 years old and when I recently had it serviced (Oil service) they recommended I had the air con service I decided to have it done as next time it will be a full "kerching" inspection service so the air con has been done but I have no doubt the cost of the service will still be the same!
KJA
153
42
South East England
Thanks folks for all the inputs really appreciate.
Maybe will get air-conditioning done next time. To me its a sealed unit if its working fine its working fine.
I don't think there is any serviceable part there. Unless its faulty or there is some refrigerant topup. But 200£ plus for that is a bit absurd.
James_R
5,663
79
37
Manchester
The system suffers natural leakage of refrigerant through seals and valves to the point it just won't function anymore. It can be up to 20% a year on some vehicles.
Having the refrigerant changed and the oil replenished helps to rejuvenate the seals, lubricate the compressor etc.
Reactions: KJA
KJA
153
42
South East England
If they do that all then its worth. Compressor oil etc. I usually don't leave the aircon dead. Even in winters give it a go for sometimes so oil and refrigerant circulate.
James_R
5,663
79
37
Manchester
You tend to find on modern A/C systems that it's always on to some degree, it's just such a small amount (1-5%) that it's barely unnoticeable and has very little impact.
It keeps things moving and prevent component failure.
