STROBE
I've got a 2004 1.8 20VT FR (from new) with 32,000 miles on the clock.
Last Thursday evening I parked after a short 10 min journey, only to see steam wafting through the beams of my headlights before I shut off. Rather concerned I jumped out and looked at the front and under the bonnet - but it was just the occasional wisp and I was unable to figure out where it was coming from.
Today after a 40 min drive I parked up and saw the steam again. I observed it coming from the left hand grill and behind the left headlamp. It didn't do it continuously, but rather in distinct periods. Steam wafts out for a minute or so, steam stops for a minute or so. Steam wafts out, steam stops. Then it didn't seem to do it any more.
There's no evidence of loss of coolant anywhere in the engine bay (at least, anywhere visible from the top), especially around the radiator hoses on the left of the car (behind the left hand grill & headlamp!) where they go into the radiator. My coolant levels have always been on the low side (even if I top it up it seems to vent it off - but it's only needed topping up once in four years, outside of services) but is stable. The oil is good, the engine runs fine, the temperature gauge is stable and there's still plenty heat in the cabin.
My dad has a theory that with the very cold weather, the radiator/coolant valve isn't opening up much during driving, but then when I slow down and stop, the cooling is reduced, so the valve opens and dumps a load of hot water into the radiator which turns the moisture on the exterior of the radiator into steam.
Any ideas what it could be? Naturally it's better safe than sorry so I don't want to leave anything to chance. Thanks in advance for any help!
On a related note, after idling the car quite a bit today after seeing the steam waft out, I was surprised the radiator fan switched on after a few minutes of idling despite the air temperature being -1°C! Is this normal?
And on a possibly related note, both my dad and I were also wondering what it is that runs for a few minutes after switching the engine off - sounds like a pump of some kind with a bit of a gurgling noise.
