chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
how do you know when your suspension is going or needs replacing?
i have the feeling my 1.4's is not what it was, i have done 67k and its a 99 plate mk2
it seems to give a lot of body roll if i hit a bump for what it should, i know the 16" mk3 cupra alloys would make a diff but it still seems too much imo
Push down on the corners of the car, and when it rebounds it shouldn't bounce. I changed my standard suspension at around 55k, and it was messed up already by then.
well i got the car around 57k and wasn't sure on the ride then but the alloys helped
it was ok then as we did that test and it was fine, however i still might replace it
is there a good suspension set which isn't too expensive and would improve the ride and lower as well? also i don't want to make the ride really hard
Alot of people went with the FK suspension from Performance Driven, had it myself on my 1.4 for over 20k, lowered just nicely, and still had some comfort to it. What size alloys are you running?
I had 20VT alloys on mine with the FK suspension, and can't complain at all about the ride. Whereabouts are you from, as if around Manchester I could recommend somewhere. Pic below is of my setup.
i am from lincoln unfortunatley and i have no idea what a good price for fitting them would be
edit - is that with a 40mm drop on yours? looks good whats the ride like in terms of speed bumps?
atm i tend to take them fairly gentley say about 10mph or so depending on the type of em
I say it would be about 3 to 4 hours work.
But if your handy with a spanner it's not that hard a job. Just make sure you've got all the right tools and about a day. Once fitted then you could take it to a good tyre place and pay to have the tracking and camber set.
i don't have the time or the skills to even attempt to do anything like that, i am guessing a couple of hundred to do the work then gotta get tracking and camber done afterwards
a couple of hundred!!! ill do it for a hundred for you. its a piece of piss honestly. i live in wakefield, bout an hour or so from manchester. its only a case of unbolt and re bolt. if you cant do it get a friend to im sure £50 and a pint would do them.
as i say ill do it for £100 just a bit of a treck thats all.
then camber and alignment would cost you bout £30 for both.
suspension is one of the easiest jobs once you've done it once. minimal tools, and virtually nothing to go array
