ok, 2001 ibiza cupra, running jabbasport remap
standard airbox
a week ago now, driving along, and traction control light comes on TCS, it wont let me turn it back on
EPC also flickers a couple of times but stays off
I ignored it, was fine next time i started the car
then 2 days later, traction control light on again, TCS and EPC, constantly on, car then goes into limp mode
disconnected battery, got about fine.
noticed fuse box, right 30amp fuse had melted above battery, changed fuse box and fuses today, no better
tonight, changed fuse box, did throttle body alignment.
started car and it's even worse now, TCS and EPC on all the time, started to idle at 1200 as normal as it was cold, then it missed a beat and sunk to 1000 revs for a second, then back to 1200, it held at 1200 for 3 seconds, then dropped to 1000, then back up
turned off car, unplugged maf, car then idled at about 1000 but sounded pretty rough, engine light also came on as expected
I thought it was to do with the fuse box, or the throttle body, as vagcom listed the only fault as being the throttlebody
plan is to
clean maf
clean throttle body
check abs sensors
that sound about right
any suggestions
abs sensors easy to check, what am i looking for, just seeing if its all plugged in fine and no wires broken or snagged
the maf is shown below right?
with the 4 blue wires and one red coming out
also whats the connection straight after the throttlebody, to the left
thanks
standard airbox
plan is to
clean maf
clean throttle body
check abs sensors
any suggestions
thanks
