TCS light stays on
dave_6
193
Essex
ok, 2001 ibiza cupra, running jabbasport remap
standard airbox
a week ago now, driving along, and traction control light comes on TCS, it wont let me turn it back on
EPC also flickers a couple of times but stays off
I ignored it, was fine next time i started the car
then 2 days later, traction control light on again, TCS and EPC, constantly on, car then goes into limp mode
disconnected battery, got about fine.
noticed fuse box, right 30amp fuse had melted above battery, changed fuse box and fuses today, no better
tonight, changed fuse box, did throttle body alignment.
started car and it's even worse now, TCS and EPC on all the time, started to idle at 1200 as normal as it was cold, then it missed a beat and sunk to 1000 revs for a second, then back to 1200, it held at 1200 for 3 seconds, then dropped to 1000, then back up
turned off car, unplugged maf, car then idled at about 1000 but sounded pretty rough, engine light also came on as expected
I thought it was to do with the fuse box, or the throttle body, as vagcom listed the only fault as being the throttlebody
plan is to
clean maf
clean throttle body
check abs sensors
that sound about right
any suggestions
abs sensors easy to check, what am i looking for, just seeing if its all plugged in fine and no wires broken or snagged
the maf is shown below right?
with the 4 blue wires and one red coming out
also whats the connection straight after the throttlebody, to the left
thanks
Nov 2, 2004
9,335
South Wales
Put that pipe back on and buy a new maf if the TCS light stays on.
Or better still, get it on vag com.
Did you buy that car with the work done?
dave_6
193
Essex
yea should have said, that pipe is only off in the picture as I was checking the throttlebody butterfly
vag com only mentioned a throttle body malfunction, nothing else
bought the car, probably about 6 weeks ago with all the work done
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
could a dodgy maf cause the problems, even after a throttlebody alignment the car idled fine, but when hot it idled at 1250, could the maf be the cause of all of this
9,335
South Wales
Does it feel better when you drive it with the MAF unplugged?
Log 002 to see what kind of figures your pulling on the maf.
dave_6
193
Essex
didnt drive it with the maf unplugged tonight
just started it, it didnt idle very smoothly so i turned it back off,
tomorrow will clean the maf and check the sensors, then go for a drive, if no luck then i'll unplug maf and try and drive it
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
just unplug your maf and drive it this will tekk you stright away if its fooked, its possible to clean then with a contact cleaner but 9 times out of 10 a new one will be best.
David.
dave_6
193
Essex
Update
disconnected battery, cleaned maf
reconnected battery, TCS and EPC already on before starting and never went off, car started, ran at 1200 revs and didnt drop down after 2 minutes, I had done a throttle body alignment aswell
took car for a drive, drove ok really slow, assoon as I tried to put any power down at all it cut back on me, cut the power sharply, a couple of times of that and then into limp mode it went
disconnected maf, idled at about 1000 and was fluctuating a bit and didnt idle smoothly
took for a drive, exact same thing, assoon as power down and it cut the power on me
what shall I do, buy a replacement maf and try that?
or could the throttle body be screwed? surely thats doubtful and maf more likely
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Im FAR from a expert and i only know what i have learnt from this site, but from what i have read it shouldnt be your maf thats causing your problems if its still doing the same as before once the maf is unplugged. Have you not got access to Vag-Com?
David.
dave_6
193
Essex
vag com showed an intermittant fault at the throttle body
not many posts on that though so unless i have a rare problem?
hoping to hook up to vag com this weekend but might get a maf asap anyway
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Like phil said log the maf (002), before you buy a new one anyway. You should be seeing around 160gs for it to be doing its job.
dave_6
193
Essex
boost gauge yep
was fine, boosting to 22psi with no problems
ko3s jabbasport remap, green filter in the airbox
intercooler
everything was fine
then one day, traction control turned itself off, car still drove fine
next time I started the car, traction control was fine again
day after, turned itself off again, and EPC light flashed a couple of times aswell
problems just got worse, then traction control went off, EPC light on, and into limp mode
Cambelt replaced and Metal Water Pump @ 50,000 miles.
Custom Jabbasport remap producing 250bhp / 285 lb.ft
K03s Sport Turbo (k03-058 unsilenced)
Custom FMIC
Red Forge Turbo Intake Pipe
All vaccum hoses replaced with red silicon
3" Blueflame 100cell race cat Downpipe leading to 2.75" Catback Scorpion, heatwrapped.
Silicon Hoses
Green Panel Filter in smoothed airbox
Heatwrapped Charge Pipe
Aquamist set at 12psi.
Forge 007p DV
4 Bar FPR
15mm spacers on rear
dave_6
193
Essex
UPDATE
Still really stuck
Today, I have checked the maf isn't the problem, jabbasport thought thats what it might be, it isnt that maf
I took off and cleaned the throttle body fully
checked the ECU area and it's got a nice cover to protect it from getting wet by the looks of it
disconnected the battery for 20-30 mins while doing the work
Did a throttle body allignment and then started the car
TCS and EPC permanently on, car was idling fine at 1200 revs
Then after 30 seconds it suddenly missed and went from 1200 down to 1000 revs, then it shot back up again to 1200, and did that a few times
then it decided to struggle really badly and was struggling and running rough at about 1000 revs
holding revs to 2000 and then letting them drop and it didnt settle or help
the only fault came up last time with vag com was
Might hook it up to vag com again later, someone local has it, but what shall we run, last time we just ran a general fault test I think and then cleared the faults
Is it looking like maybe the throttle body needs to be replaced, 2nd hand or new one
I'm stuck and not far off booking it in with Seat
dirty throttle body, not really that bad though is it
cleaned up
dave_6
193
Essex
the ECU, in the top pic, it would be under that grey covering wouldnt it?
I saw the cover there and didnt take it off as it looked like it would be safe under there
I found this post by someone on the forums
"Could well be the throttlr body
My 1.8t one went a couple of weeks ago. It lost resolution at the bottom end, and eventualy wouldn't tick over propperly. It threw this code.
17953 - Throttle Valve Controller: Malfunction"
dave_6
193
Essex
All I can think of is
throttle body has had it
or ecu is wet, but it looks safe if i think its where it is
dave_6
193
Essex
UPDATE from today
went back again, this time I took of the throttle body plastic side part and cleaned the electrics with electrical cleaner, didnt look coroded inside anyway
reconnected battery, did throttle body allignment, started the car
started better than before
Traction control TCS and EPC lights still on, but it was idling fine at 1200 revs, sitting steady, then after 2 minutes it all went wrong
revs just died to 1000, didnt lower gently like it should down to 900, just stuttered and then ran rough at 1000 revs
turned off and hooked to vagcom
faults at the throttle body, clear them and it comes straight back
and also an abs fault which explains the EPC and TCS lights
few scrappies have cupras in at the moment , one is local so going to try them tomorrow and hopefully get a throttle body off them to clean up and then try
as you can see the ecu is safe under here, water proof cover
inside the throttle body
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
id be a bit worried why that has a cover over the ecu in the first place? has it had problems with water in the ecu before you had it?
dave_6
193
Essex
its been remapped by jabbasport so at a guess its been put there either by them or the previous owner for safety as its a crap place for the ecu to be
