If you press the clutch in does the engine rev to the limiter or to around 2-3,000 rpm?if its the later,could be coolant temp. sensor faulty,i had this fault.Vag-com is the way forward though!
Yes it has done that a couple of times, right up to about 6k, the first one I thought it was my fault in going back to driving a manual but the second time I realised it was the car
How many clutch pedal sensors are there and are they all easy to change?
