Tools to cut back of light cover?
jamiebennett81
fitting my HID's, what have people used to cut a hole in the back of the casing?
thinking of using a drill or dremel cut it out, but I want the hole to be spot on
seen this:
http://www.toolspot.co.uk/product/toolzone-adjustable-circle-hole-cutter-m2-steel?source=froogle
can it be used in just a normal black and decker without speed control/variation
jamiebennett81
Yeah that be fine 25mm you it set too.
Any drill will do it, or mark a 25 mm diameter hole and dremel it out.
thanks mate
think I will get it as I am sure it will come in use again
jamiebennett81
thanks
one more thing, I am looking for some small bolts for the bracket on my catch can
about 2-4mm wide and no longer than 8mm max (preferably hex ended)
jamiebennett81
dunno if i'm supposed to do this, so sorry to the mods if i'm not:thumbup:
jamie, trying to contact you over the dv relocation kit, my e-mail ain't workin:confused:
sorry, inbox was full as usual:rolleyes::whistle:
try again mate
Ronin225
4,652
22
Worcester
a decent step drill will do it, each incrament is about 2mm.
normally use these or q max cutters for putting the round hole in electrical panels and dish boards
ginger prince
i used a step drill, pretty cheap from screwfix. and much more "adjustable" then a flat bit if you need it for anything else in the future
sparkz002
As above, a step drill bit. Can be pricey though forthe large ones that go from 10mm up to 30mm in 2mm increments. I paid £25 mine, but i use it more or less daily for the line of work im in.
Dec 6, 2008
612
Shropshire
I used a step drill aswell, mine was £15 from screwfix I think and goes in 2mm increments up to 22mm. which with a waggle gets you near enough there. It doesnt have to be exact and is better slightly tight than loose.
Step drills are actually very useful I use mine for cutting metal of car bodies and also plastic when i'm fitting ipod kits, they cut a very tidy hole and dont try and run away with you
Richie-LCR
139
ayrshire
sorry if this is a dumb question but why do you need to cut a hole in the headlight? do the bulbs not fit in or something?
