track car lcr
L280R
153
I'd personaly stick with the leon. I've just come back from there in mine. Its got coilovers, role bar, spacers, dog bone mount and new goodyear f1s and it was immense. Handles like a dream. I went in a totally standard lcr 4 yrs ago and it was no were near as good! Go for the handling then the engine. When you get a map etc get the intercooler first, smic won't stand up to the ring. I had a vx220 turbo last year and i was a couple of secs quicker this year. Ended up with a 8.49 btg. A well sorted leon is better in my opinion. You also feel safer so push more. In the vx i was always aware of the barriers, have a bump in one of those there you might not get out of it!!!!!!!!!
scottslb1111
49
selby
the dog bone mount whats does it do to improve ur car??? ive seen alot of leon have this changed. did u changed both ur anti roll bars?? .
How did the brakes hold up.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Scott,
Any chance you could give us the full spec of your car with all non standard bits listed to help and advise you better?
Do you have a Readers Rides section thread?
scottslb1111
49
selby
i dont have a readers ride i will try sort one out to make it easier 4 u lot. i ant done that much really. but for now i will just put it on here 4 ya.
engine. forge dv and induction kit. remapped to 258 bhp.
ap coilover, think it has a r32 anti roll bar at the front and the bushs where changed at the same time. Porche rims on it but they will be changed for some light weight ones.
Ive not had the car that long. hope this helps
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup that's a good start.
How much lower is your LCR than OEm ride height?
With a rear adjustable ARB and an S3 strutt brace you will be feeling well good on corners.
I've gone for 25mm drop from the OEM ride height, I have a track day on the 8th of August that I'll mess about wit the ride height to see what differences it gives but so far 20-25mm drop seems good.
You really want to keep the wishbone arms parallel with the ground, at 25mm drop there just off of this, I'll try 20mm drop first to see how this differs.
Don't overlook good rubber, I have used GYE F1 Asymmetrics for a while and love them. Not really tested them real hard on the track but what I've done so far they feel good
L280R
153
Dogbone mount basically stops the engine form moving under hard acceleration. Meant to give more vibration but i didn't really notice that much difference. I've got the ap coilovers. The goodyears are definatly the tyres to get. ust the rear role bar. Its actually my mates bar!
scottslb1111
49
selby
at the min mine is to low to be honest. Noy sure how much lower but the front spoiler catchs all the time. Im going to winde it up when i start trackin it. I went down the low and wide look but its to unpractical. i will defos put the rear ARB and s3 anti roll bar down on the list then cheers for that. Im think about going for toyo r888 for when its on the track. I just need to decide on the wheels to go for.
L280R
153
they need to be the last thing i'd say. brakes everything need to be done before they go on. 888 give the car a stupid amount of grip. The car will need to be stiff or you will just be roling everywhere because theres so much grip form tyres
scottslb1111
49
selby
that the only down side of the ap there not adjustable. what do u mean they need to be the last thing??? am confussed.
r ur brake standard ??? how did they cope with the ring??
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
how much cash you got spare fella.....
as said forget the power mods at the minute
go for this.....
1. get the ap coilies setup right, cornerweighted etc.
2. get a 4 wheel laser alignment done £65+
3. s3 upper brace £60
4. s3 lower brace £30
5. rear arb £150+
6. new top mounts and bearings £30
7. rear 10mm spacers £60
8. decent rubber, gsd3, falken f452, assym £400
9. quaife atb..... £1000 ish fitted
10. tt wishbone bushes £20
brakes.
standard discs and ferodo ds2500 pads...........
now after that little lot youll be sticking to the road like a slow hedgehog mate.
save, and enjoy.
im at then mods now, and can personally say its friggin awesome
L280R
153
well i got new discs form crn, new ds2500's and race brake fluid. When i was there it was 28 degrees. I done about 18 laps on a very fast pace and the brakes never missed a beat. The brembo calipers are genuinely a good caliper. Maybe a 2 piece disc next time but it defo isn't a must. I mean that if you stick a set of 888's on a near standard car the suspension wont be able to keep up. You would be on the door handles because the tyres offer so much grip but the suspension wouldn't be stiff enough to stop role.
scottslb1111
49
selby
i see what u mean now about the tyres. everyone at the ring said they grip like no other tyres. im not a hundred percent sure what a quaife atb is?????
Will need to get the top mounts and bearin cause pass side have started make a noise so i will change them when i get strutbrace. then just need the rear anti roll bar. cheers everyone ur all i graet help.
scottslb1111
49
selby
cheers for that i fort it was to do with diff but want sure. going to go s3 stust brace and get back anti roll bar then see how car feels
