Vredestein are the best tyre manufacturer for 'feel' tyres. I have had sessantas and vortis (even better).
The trick is the pressures. Vreds take a higher pressure than other tyres. Try a fast roundabout and if the sidewalls give (you'll feel it), put a bit more pressure in (they usually run 4-8psi above others) get these right and there is no better tyre. They stop when you desperately need to, which is where it counts.
Note: The tyres are a little heavier (especially vortis with the rigid sidewall) than others. But I like this 'fault' as it is more tyre. They are also slightly wider and they are one of the only tyres not made in China (but in the Netherlands).
Get the pressure right and these are incredible. Don't and the sidewalls have a soggy feel, but they will still be comfortable, quiet and stop well.
