I took my car in this morning to have a few things looked at but not had much luck with them:
Belt/whining noise from engine (see here) - Apparentley this is normal! I'm sure it can't be as it is quite audible over the engine sound when idle, plus I can hear a slight turbine noise when accelerating hard at about 2500-4000 rpm (higher pitched than usual turbo noise).
Climate control display flashing all digits when turning on ignition - This seems to have happened to a few people on here and I even get a '00792 - A/C Pressure Switch (F129)' fault with Vag-Com. This is also normal apparently although I didn't get it on my old Cupra..
Crunching from gearbox sometimes, usually when engaging reverse from when parked - They said they could only replicate this when changing gears fast as it has a 'sporty gearbox'. I dont usaully engage reverse fast when pulling away from standstill!
Rear washer not spraying onto window - They couldn't really say this was normal so have adjusted it.
They said they heard a knocking noise from suspension and that the 'droplinks' need replacing, which they will try and do tomorrow.
So am I hearing things or are they just trying to get out of actually doing anything with my car before the warranty expires at the end of the month?![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Excuse the long post but surely at least the first 2 issues need looking at again?
